Component: IoT Made Easy (Comms: IoT/Cloud)
Revision as of 17:21, 9 November 2022 by Wiki bot (talk | contribs)
Category Comms: IoT/Cloud
IoT Made Easy component
A component designed to simplify MQTT comms allowing for multiple data streams to be dealt with in a simple manner. Deals with translating values to and from the broker from topic strings into message IDs and numeric values. Works with lots of different MQTT brokers.
FREE
Fc9-comp-macro.png ErrorAsString
Fc9-u8-icon.png - BYTE Error
Fc9-comp-macro.png PublishString
Publishes data to the selected topic ID using a data string. Returns none zero if successful
Fc9-u8-icon.png - BYTE TopicID
The topic ID to publish data to
Data string to publish
Fc9-comp-macro.png GetTopicID
Compares the topic ID of the last received message with enabled IDs. Returns the topic ID received.
Fc9-comp-macro.png Connect
Connect to the MQTT Server. Returns the connected state. 0 if not connected, 1 if successful connection, or already connected.
Fc9-comp-macro.png GetPayloadInteger
Get the Payload of the last received (Read) packet as a signed long value
Fc9-comp-macro.png LastError
Returns the last error
Fc9-comp-macro.png Read
Read incoming data. Returns non-zero if packet received. Use GetTopicID and GetPayloadXXX to read the contents.
Fc9-comp-macro.png Disconnect
Disconnects from the MQTT server and the network
Fc9-comp-macro.png PublishFloat
Publishes data to the selected topic ID using a floating point value. Returns none zero if successful
Fc9-f32-icon.png - FLOAT Data
Data to publish
Fc9-comp-macro.png Ping
Ping packet is sent to the server and checks for a reply. If nothing is sent or received within the keep alive period then a ping is required to keep the connection to the server active. Returns non-zero value if successful
Fc9-comp-macro.png PublishInteger
Publishes data to the selected topic ID using a signed long integer value. Returns none zero if successful
Fc9-s32-icon.png - LONG Data
Data to publish
Fc9-comp-macro.png GetPayloadFloat
Get the Payload of the last received (Read) packet as a floating point value
Fc9-comp-macro.png GetPayloadString
Get the Payload of the last received (Read) packet as a string value
Fc9-string-icon.png - STRING Payload
Fc9-u8-icon.png - BYTE Size
Fc9-comp-macro.png Initialise
Starts up the MQTT component - call this after initialising the NetworkComms component.
Fc9-conn-icon.png MQTT Properties
Fc9-type-10-icon.png Host
Address of MQTT Broker Can be an IP Address or URL (URL only supported by some hardware platforms)
Fc9-type-21-icon.png Port
Port used by MQTT Broker Default 1883 for unencrypted access and 8883 for encrypted access.
Fc9-type-10-icon.png Client identifier
Client identifier (Maximum length 20 characters) Must be unique to the broker.
Fc9-type-21-icon.png Network Timeout
Maximum time in mS to wait for network responses
Fc9-type-21-icon.png Read Timeout
Time to wait in ms when waiting for incoming messages
Fc9-type-21-icon.png Keep Alive
The Keep Alive is the maximum time interval that is permitted to elapse between the point at which the Client finishes transmitting one Control Packet and the point it starts sending the next, measured in seconds.
Fc9-type-17-icon.png Network Component
Pointer to the network communications component providing TCP simulation and abstraction for embedded TCP modules.
Fc9-type-16-icon.png Authentication
Selects if the broker is open or if the broker requires a username and password.
Fc9-conn-icon.png Topics
Fc9-type-16-icon.png Number of topics
Sets the number of data topics that can be sent or received
Fc9-conn-icon.png Topic ID: 0
Fc9-type-10-icon.png Topic String
Fc9-type-16-icon.png Topic Type
Fc9-conn-icon.png Topic ID: 1
