Component: LIN Slave (Comms: Interface)
Revision as of 17:21, 9 November 2022 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix Ltd |- | width="20%" style="color:gray;" | Version | 1.2 |- | width="20%" style="color:gray...")
Version 1.2
Category Comms: Interface
LIN Slave component
Low level routines for controlling the LIN bus (1.3 / 2.0) slave interface.
COMMSC
Fc9-comp-macro.png PowerDown
Puts the bus into the Powered Down state driving the CS pin low.
Fc9-comp-macro.png ListenForMessages
Listens for messages with Timeout and returns the state. Returns 255 for timeout, 254 for CRC error and 0 for none matching ID received. Returns 1-8 for a valid ID received.
Fc9-u8-icon.png - BYTE Timeout
timeout in milliseconds to wait for incoming message, 255=Wait Forever
Fc9-comp-macro.png ReadDataCount
Return the data count size for Message
Fc9-u8-icon.png - BYTE Message
Range: 1 - Num Messages
Get the Message data automatically received from a specific message as part of the ListenForMessages macro.
Message index to be read. Range: 1 - Num Messages
Fc9-u8-icon.png - BYTE Data
Fc9-comp-macro.png SetData
Set the Message data to be automatically sent for a specific message as part of the ListenForMessages macro.
Message index to write. Range: 1 - Num Messages
Fc9-comp-macro.png WakeUp
Puts the bus into the Wake state driving the CS pin high.
Fc9-comp-macro.png Initialise
Initialises the device ready for communications from the master. Puts the bus into the Wake state driving the CS pin high.
Fc9-conn-icon.png Bus Options
Fc9-type-16-icon.png Channel
Fc9-type-16-icon.png Baud Options
Fc9-type-16-icon.png Messages
Number of messages the firmware is designed to listen for
Fc9-type-16-icon.png Checksum Type
Fc9-type-5-icon.png TX
Fc9-type-5-icon.png RX
Fc9-type-5-icon.png CS pin
LIN bus chip select pin
Fc9-conn-icon.png MESSAGE1
Fc9-type-14-icon.png ID
Message identifier to listen for
Fc9-type-16-icon.png BYTES
Number of bytes to expent in the packet
Fc9-type-16-icon.png TX_RX
Data direction for packet
Fc9-conn-icon.png Simulation
Fc9-type-16-icon.png Console Format
Controls if the data is shown as a log with time and date stamps or just as raw data
Fc9-type-21-icon.png Console Columns
Fc9-type-16-icon.png Data Source
Simulation data source used to allow the component to connect to various remote devices Nothing - Simulation data is ignored COM port - Routes the communication data to and from a physical or virtual COM port API - Routes the communication data via a data injector component on the Panel.
