Component: MIAC NXT AllCode API (AllCode)
Revision as of 17:21, 9 November 2022 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix TSL |- | width="20%" style="color:gray;" | Version | 1.1 |- | width="20%" style="color:gray...")
Version 1.1
Category AllCode
MIAC NXT AllCode API component
Controls the MIAC NXT hardware loaded with the MIAC NXT AllCode firmware. Usefull for SCADA, Control or Test applications. Compatible with USB / Bluetooth / Wifi / Ethernet
FREE
Here is a basic example program that reads the UID from a Mifare RFID tag and displays on an LCD. If the UID matches the UID stored in memory then a solenoid will fire allowing a door to be unlocked etc.
FC6 Icon.png Display UID
Here is a basic example program to read and modify data stored on a Mifare RFID tag.
FC6 Icon.png Read Write Test
Fc9-comp-macro.png WriteTranPWMEnable
Allows pulse width modulated transistor outputs to be switched on or off.
Range: 1-4 Where 1=A / 2=B / 3=C / 4=D
Fc9-bool-icon.png - BOOL EnableOrState
PWM on Enable Pin or State Pin - 1 = Enable / 0 = State
Fc9-bool-icon.png - BOOL OnOrOff
1 = Enabled / 0 = Disabled
Fc9-comp-macro.png WriteTrans
Allows all transistor outputs to be switched on or off in a single command.
Fc9-u8-icon.png - BYTE Value
Range: 0-63 or 0b000000 to 0b111111
Fc9-comp-macro.png DisplayPrint
Prints a string to the MIAC display starting from the current cursor position.
Fc9-string-icon.png - STRING data
Range: 0-21
Fc9-comp-macro.png GetAPIVersion
Gets the API version of the MIAC NXT AllCode Firmware. Useful to see if the MIAC NXT is responding to commands.
Fc9-comp-macro.png DisplayNumber
Prints a number to the MIAC display starting from the current cursor position.
Fc9-s32-icon.png - LONG Value
Range: Signed Long
Fc9-comp-macro.png WriteTranPWMDuty
Sets the PWM duty on the selected channel.
Fc9-u16-icon.png - UINT Duty
Fc9-comp-macro.png DisplayClear
Clears the MIAC display
Fc9-comp-macro.png ReadKey
Reads a keypress from the keypad. Returns 0 for no keypress or 1-9 for a valid keypress. 1 = TopLeft, 2=TopMiddle, 3=TopRight, 4=CenterLeft etc
Fc9-comp-macro.png DisplayPixel
Controls a single pixel on the MIAC display
Fc9-u8-icon.png - BYTE X
Range: 0-119
Fc9-u8-icon.png - BYTE Y
Range: 0-31
Fc9-bool-icon.png - BOOL State
Range: 0-1
Fc9-comp-macro.png WriteRelay
Allows a single relay to be switched on or off.
Range 1-2
Fc9-bool-icon.png - BOOL Value
0 = Off, 1 = On
Fc9-comp-macro.png WriteRelays
Allows all relays to be switched on or off in a single command.
Range: 0-3 or 0b00 to 0b11
Fc9-comp-macro.png ReadAnalogInput
Reads a single analog input with range 0 to 4095 corresponding to input voltage 0V to +V.
Range: 1 - 8
Fc9-comp-macro.png SetAPIVerbose
Controls the Verbose mode. When enabled the LCD automatically displays an account of the incoming API commands and parameters. When switched off the LCD is free for the user to control as required.
Fc9-bool-icon.png - BOOL Mode
Range: 0-1 : 0=Off or User Mode / 1=API Verbose Mode
Fc9-comp-macro.png DisplayCursor
Sets the cursor position for the MIAC display
Range: 0-21
Range: 0-3
Fc9-comp-macro.png ReadDigitalInput
Reads a single digital input.
Range: 1 - 8
Fc9-comp-macro.png ReadDigitalInputs
Reads all digital inputs at once and returns as a binary value. Input 1 = Bit 0 Input 8 = Bit 7
Allows a single transistor output to be switched on or off.
Range 1-6 where 1=A / 2=B / 3=C / 4=D / 5=E / 6=F
0 = Off, 1 = On
Fc9-comp-macro.png DisplayFloat
Prints a floating point number to the MIAC display starting from the current cursor position.
Range: Float
Fc9-u8-icon.png - BYTE NumDP
Number of decimal places to display
Fc9-type-16-icon.png API Connection Type
API connection mode. COM - Bluetooth / RS232 / RS485 WIFI - Network
Fc9-type-7-icon.png Warnings On Error
Generates a warning dialogue if the communication to the device fails allowing the program to be ended.
Fc9-conn-icon.png Connection Properties
Fc9-type-7-icon.png Auto Detect
