Component: MIAC (dsPIC) (MIAC (dsPIC)) (MIAC Module)
Revision as of 17:21, 9 November 2022 by Wiki bot (talk | contribs)
Version 1.2
Category MIAC Module
MIAC (dsPIC) component
MIAC - Matrix Industrial Automotive Controller (dsPIC)
FREE
Fc9-comp-macro.png RelayOFF
Turns off the requested relay given by parameter RelayID, values 1 to 4
Fc9-u8-icon.png - BYTE RelayID
The relay to turn off. From 1 to 4.
Fc9-comp-macro.png InputANALOG_10Bit
Fc9-u8-icon.png - BYTE InputID
The input to read. From 1 to 8.
Fc9-s16-icon.png - INT Return
Fc9-comp-macro.png PrintString
Prints the given character string to the display at the current cursor position and moves the cursor position.
The string to send to the display.
Fc9-comp-macro.png GetKeypad
Returns the key code of the key that is pressed, otherwise if nothing is pressed then returns 255
Fc9-comp-macro.png DisplayStart
Initialise the display ready for use
Prints the given number to the display starting at the current cursor position and moves the cursor position.
Fc9-s16-icon.png - INT n
Fc9-comp-macro.png PrintASCII
Prints the given character to the display at the current cursor position and increments the cursor position.
Fc9-u8-icon.png - BYTE Char
ASCII code of the character to print.
Fc9-comp-macro.png DrawLine
Draws or clears a line from start at sx:sy to end at ex:ey
Fc9-u8-icon.png - BYTE sx
Start column position
Fc9-u8-icon.png - BYTE sy
Start row position
Fc9-u8-icon.png - BYTE ex
End column position
Fc9-u8-icon.png - BYTE ey
End row position
Fc9-u8-icon.png - BYTE state
1=active pixel, 0=cleared pixel
Fc9-comp-macro.png PrintFormattedNumber
Fc9-u32-icon.png - ULONG Number
Fc9-bool-icon.png - BOOL Format
0=Signed, 1=Unsigned
Fc9-comp-macro.png DrawRect
Draws a rectangular box from x1,y1 to x2,y2
Fc9-u8-icon.png - BYTE x1
Fc9-u8-icon.png - BYTE y1
Fc9-u8-icon.png - BYTE x2
Fc9-u8-icon.png - BYTE y2
1=draw pixel, 0=clear pixel
Fc9-comp-macro.png DisplayClear
Clears the display to white space
Fc9-comp-macro.png RelayON
Turns on the requested relay given by parameter RelayID, values 1 to 4
The relay to turn on from 1 to 4.
Fc9-comp-macro.png OutputOFF
Outputs a digital low state on the output requested by parameter TransID (Outputs 1 to 4)
Fc9-u8-icon.png - BYTE TransID
1 to 4 (Outputs A to D)
Fc9-comp-macro.png DrawPixel
Draws, or clears, a pixel at point x,y
Fc9-u8-icon.png - BYTE px
Fc9-u8-icon.png - BYTE py
state = 0 clears the pixel, else draws the pixel
Fc9-comp-macro.png DisplayCursor
Moves the display cursor to the given position. If the cursor is set to the origin at x=0, y=0, then the next character sent to the display will appear in the top left corner.
Position of the cursor in characters from left to right.
The line to move the cursor to.
Fc9-comp-macro.png OutputON
Outputs a digital high state on the output requested by parameter TransID (Outputs 1 to 4)
Fc9-comp-macro.png InputDIGITAL
Returns the digital state of the input requested by parameter InputID (Inputs 1 to 8)
The input number from 1 to 8.
Fc9-comp-macro.png DisplayLight
Turns the display backlight on or off
Fc9-comp-macro.png DrawGlyph
Draws a character glyph on the display at position px, py
Fc9-u8-icon.png - BYTE glyph
The glyph ident number
pixel column relative to the drawing origin (top left)
pixel row relative to the drawing origin (top left)
Fc9-u8-icon.png - BYTE mode
0=opaque/cleared background, 1=transparent background
Returns the 8 bit value for the analogue input requested by parameter InputID (Inputs 1 to 8)
The input to read from 1 to 8.
