Component: MIAC (PIC) CAN Slave (MIAC: Addon Modules)
Jump to navigationJump to searchAuthor | Matrix Ltd |
Version | 1.4 |
Category | MIAC: Addon Modules |
MIAC (PIC) CAN Slave component
MIAC Slave for MIAC System. Requires Slave firmware program downloaded to a MIAC (PIC) to act as a CAN connected Slave device.
FREE
InputANALOG_10Bit |
Returns the 10 bit value for the analogue input requested by parameter InputID (Inputs 1 to 8) | |
InputID |
The input to read from 1 to 8. | |
Return |
RelayOFF |
Turns off the requested relay given by parameter RelayID, values 1 to 4 | |
RelayID |
The relay to turn off. From 1 to 4. | |
Return |
PrintString |
Prints the given character string to the display at the current cursor position and moves the cursor position. | |
Str |
The string to send to the display. | |
Return |
GetKeypad |
Returns the key code of the key that is pressed, otherwise if nothing is pressed then returns 255 | |
Return |
DisplayStart |
Initialise the display ready for use | |
Return |
DisplayCommand |
Sends the given command to the display | |
Cmd |
Return |
PrintASCII |
Prints the given character to the display at the current cursor position and increments the cursor position. | |
Char |
ASCII code of the character to print. | |
Return |
PrintNumber |
Prints the given number to the display starting at the current cursor position and moves the cursor position. | |
n |
Return |
MIAC_Module_SetData |
Count |
D0 |
D1 |
D2 |
D3 |
D4 |
D5 |
Return |
MIAC_Module_Init |
CAN_ID |
Return |
MIAC_Module_GetData |
Index |
Return |
MIAC_Module_Message |
CAN_ID |
CMD_ID |
Return |
DisplayClear |
Clears the display to white space | |
Return |
MIAC_Module_WR |
CAN_ID |
CMD_ID |
[[File:]] - | Count |
[[File:]] - | Start |
[[File:]] - | More |
Return |
MIAC_Module_PushData |
Data |
Return |
OutputOFF |
Outputs a digital low state on the output requested by parameter TransID (Outputs 1 to 4) | |
TransID |
1 to 4 (Outputs A to D) | |
Return |
RelayON |
Turns on the requested relay given by parameter RelayID, values 1 to 4 | |
RelayID |
The relay to turn on from 1 to 4. | |
Return |
OutputON |
Outputs a digital high state on the output requested by parameter TransID (Outputs 1 to 4) | |
TransID |
Return |
InputDIGITAL |
Returns the digital state of the input requested by parameter InputID (Inputs 1 to 8) | |
InputID |
The input number from 1 to 8. | |
Return |
MIAC_Module_GetAck |
CAN_ID |
CMD_ID |
TimeOut |
Return |
InputANALOG |
Returns the 8 bit value for the analogue input requested by parameter InputID (Inputs 1 to 8) | |
InputID |
Return |
Properties |
Module Type |
Module Address |
