Component: Slider control (Advanced Shapes)
Revision as of 17:21, 9 November 2022 by Wiki bot (talk | contribs)
Version 1.1
Category Advanced Shapes
Slider control component
A simple graphical interface for a vertical meter or slider control. This can be used within custom components to give them a way to display an analogue value, or to allow setting a value by clicking and dragging with the mouse.
MODELS
Simple example showing how to use the simulation slider component as a meter display for use in monitoring type applications. FC6 Icon.png Meters
Fc9-comp-macro.png GetValue
Gets the current value of the slider. This will be within the range set by the SetRange macro.
Fc9-comp-macro.png SetValue
Set the current value of the slider. This will override any value set by using the mouse.
The value to set.
Fc9-comp-macro.png SetInteractive
Set whether the mouse can be used to change the slider value.
Fc9-bool-icon.png - BOOL Enable
Set true to allow clicks to set scale
Fc9-comp-macro.png ShowScale
Set whether graduated marking are shown along the length of the slider.
Fc9-bool-icon.png - BOOL Show
True to show scale, else false
Fc9-comp-macro.png SetRange
Set the minimum and maximum values that can be shown on the slider.
Fc9-s16-icon.png - INT Min
Min (start) value
Fc9-s16-icon.png - INT Max
Maximum (end) value
