Component: Modbus Slave USB (Comms: System)
Revision as of 17:21, 9 November 2022 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 2.0
Category Comms: System
Modbus Slave USB component
Modbus component for creating Modbus compatible slave hardware via USB Serial.
COMMSC
Example master program to control the slave. The example sets coil address 0, clears coil address 0, reads an input register and outputs to the LCD. Be sure to set the IP address of the slave device at the top of the program. If you are simulating then use the IP address of the PC running the Slave simulation. Both programs can be simulated on the same PC using two instances of Flowcode.
FC6 Icon.png Modbus TCP Master Example
Example slave program to react to the signals from the master. The example listens for Modbus commands from the master and outputs the current coils 0 state to an LED connected to PortA. The input register is loaded with a value which is incremented on each Modbus transaction.
FC6 Icon.png Modbus TCP Slave Example
Addressing
Data Type Common name Starting address Ending Address Flowcode Start Address Flowcode End Address
Modbus Coils Bits, binary values, flags 00001 10000 0 9999
Digital Inputs Binary inputs 10001 30000 0 19999
Analog Inputs Binary inputs 30001 40000 0 9999
Modbus Registers Analog values, variables 40001 60000 0 19999
Fc9-comp-macro.png ReadHoldingRegister
Reads the value of a single holding register.
Fc9-u16-icon.png - UINT Address
Coil Address
Fc9-comp-macro.png SetCoil
Sets the state of a single digital coil.
Coil Address
Fc9-u8-icon.png - BYTE State
0=off, 1=on
Fc9-comp-macro.png SetDigitalInput
Sets the state of a single digital input.
Coil Address
0=off, 1=on
Fc9-comp-macro.png SetSlaveAddress
Allows the slave address to be overridden from the default slave address specified in the component property. The number of bytes used for the address is fixed by the Slave ID Bytes property to save on RAM usage.
Fc9-u16-icon.png - UINT SlaveAddress
Fc9-comp-macro.png ChangeFrameType
Default frame type is the type set in the component properties.
Fc9-u8-icon.png - BYTE Type
0 = Modbus RTU / 1 = Modbus ASCII
Fc9-comp-macro.png ReadCoils
Reads the state of a single digital coil. Can pack a max of 8-bits together in a single operation
Fc9-u16-icon.png - UINT StartAddress
Coil Address Range 0 to (NumCoils - 1)
Fc9-u8-icon.png - BYTE AddressCount
Range 1-8
Fc9-comp-macro.png SetHoldingRegister
Sets the state of a single holding register.
Coil Address
Fc9-u16-icon.png - UINT Value
Analogue Value range 0 - 65535
Fc9-comp-macro.png ReadAnalogInput
Reads the value of a single analogue input.
Coil Address
Fc9-comp-macro.png CheckForIncoming
Checks for an incoming message and if the data address is within range then also automatically replies with the correct reply. Returns 0 if no comms received, 1 for a succesful transaction, 255 for an error.
Fc9-comp-macro.png ReadDigitalInputs
Reads the state of a single digital input. Can pack a max of 8-bits together in a single operation
Range 1-8
Fc9-comp-macro.png GetLastIncoming
Gets a value from the last incoming command. Index 0 = 0 Read / 1 Write Index 1 = 0 Coils / 1 DigInput / 2 AnInput / 3 Register Index 2 = Address Index 3 = Number
Fc9-u8-icon.png - BYTE Index
Range 0-3
Fc9-comp-macro.png SetAnalogInput
Sets the state of a single analogue input.
Coil Address
Fc9-comp-macro.png Initialise
Starts up the UART to allow communications and initialises the states of the various Modbus Coils, Inputs and Registers to 0. Returns 1 if USB is started ok.
Fc9-conn-icon.png USB Properties
Fc9-type-21-icon.png Vendor ID
USB VID
Fc9-type-21-icon.png Product ID
USB PID
Fc9-type-10-icon.png Device Name
USB Device Name
Fc9-type-10-icon.png Manufacturer
USB Manufacturer
Fc9-type-14-icon.png Major Version
USB Major Version Number
Fc9-type-14-icon.png Minor Version
USB Minor Version Number
Fc9-type-16-icon.png Return Type
Specifies the way the receive function indicates a timeout. 8 Bit mode - Timeout is represented by the value 255. 16 Bit mode - Timeout is represented by the value 512 allowing the value 255 to represent valid data
Fc9-type-7-icon.png Enumeration Timeout
Specifies if the enumeration (Initialise function) can timeout if taking too long.
Fc9-conn-icon.png USB Driver
Fc9-type-20-icon.png Driver Directory
Directory to save the generated device driver .inf file
Fc9-type-10-icon.png Driver Filename
Filename to give to the generated driver file.
Fc9-type-7-icon.png Generate Driver
Generates a driver file when set to Yes, Automatically jumps back to No when complete.
Fc9-conn-icon.png Modbus Properties
Fc9-type-21-icon.png Timeout
Timeout in milliseconds used to dictate the maximum time to wait in milliseconds between bytes in a packet. Range: 1 - 255
Fc9-type-16-icon.png Frame Type
Switches between RTU and ASCII forms of Modbus
Fc9-type-21-icon.png Receive Buffer Size
Fc9-type-21-icon.png Slave ID Bytes
Fc9-type-21-icon.png Slave Address
Fc9-type-21-icon.png Reply Delay
Delay in micro seconds to wait before transmitting a reply
Fc9-type-7-icon.png Maintain Stats
Controls if the last command from the master is logged allowing for easier value updates. No - Do not log commands Yes - Commands are logged and available via the GetLastIncoming macro
Fc9-conn-icon.png Simulation Properties
Fc9-type-10-icon.png Label
Fc9-type-12-icon.png COM Port
Hardware COM port to communicate with any connected USB serial devices or any other virtual COM ports.
Fc9-conn-icon.png Modbus Coils - Single bit values
Fc9-type-21-icon.png Starting Address
Start address of the Modbus coils. Referenced from 0. For example Slave 1 might have 100 coils addressed 0-99 Start Address = 0 Slave 2 might have 100 coils addressed 100-199 Start Address = 100
Fc9-type-21-icon.png Number of Addresses
Specifies how many Coils are available on the slave. Each address consumes a single bit of RAM, 8 Addresses are packed together into a single RAM Byte.
Fc9-conn-icon.png Digital Inputs - Single bit values
Start address of the Modbus digital inputs. Referenced from 0. For example Slave 1 might have 100 inputs addressed 0-99 Start Address = 0 Slave 2 might have 100 inputs addressed 100-199 Start Address = 100
Specifies how many Digital Inputs are available on the slave. Each address consumes a single bit of RAM, 8 Addresses are packed together into a single RAM Byte.
Fc9-conn-icon.png Analog Inputs - 16-bit values
Start address of the Modbus analogue inputs. Referenced from 0. For example Slave 1 might have 100 inputs addressed 0-99 Start Address = 0 Slave 2 might have 100 inputs addressed 100-199 Start Address = 100
Specifies how many 16-bit analogue inputs are available on the slave. Each address consumes two RAM Bytes.
Fc9-conn-icon.png Holding Registers - 16-bit values
Start address of the Modbus registers. Referenced from 0. For example Slave 1 might have 100 registers addressed 0-99 Start Address = 0 Slave 2 might have 100 registers addressed 100-199 Start Address = 100
Specifies how many 16-bit holding registers are available on the slave. Each address consumes two RAM Bytes.
