Component: Network Communications (Comms: Networking)
Revision as of 17:21, 9 November 2022 by Wiki bot (talk | contribs)
Version 1.5
Category Comms: Networking
Network Communications component
A component designed to simplify the process of TCP/IP communications. Compatible with most of the Flowcode supported TCP/IP and WIFI components. A useful building block for creating components such as IoT and Modbus TCP.
FREE
Here are some examples showing the Network Communications component in action.
By itself the component provides a generic TCP/IP layer to drive the simulation runtime.
Here is a simple example showing the component used by itself to request data from a remote server on the internet.
FC6 Icon.png Example Network Comms Client
Library Components
Components such as Webserver (GENERIC), MQTT and Modbus TCP can connect to and control the network comms layer.
Here is a simple example showing the component used with the Webserver (GENERIC) component.
FC6 Icon.png Example Network Comms Web Server
Embedded Components
The Network Communications component can also be connected to embedded TCP/IP and WIFI style modules allowing for the abstraction to work with specific networking hardware modules.
Here is the current status of the Network Communications component with the various embedded modules.
Embedded Component Other Variants of Component Support Status
TCP/IP (Raspberry Pi) N/A Fully Supported
WLAN (ESP8266) WLAN (ESP-12S), WIFI (BL0136), WIFI (ESP8266) Fully Supported
TCP/IP (W5500) N/A Fully Supported
ENC28J60 N/A On Hold
TCP/IP (NM7010A) TCP/IP (EB023v1) On Hold
TCP/IP (W5100) TCP/IP (EB023v2), TCP/IP (WIZ810MJ) On Hold
WLAN (WIZ610WI) WIFI (EB069) On Hold
We are working through and adding support as and when we get chance so if you have a module that isn't listed or would like to try and prioritise a specific module then you can let us know via the user forums.
Fc9-comp-macro.png Connect
Connects to an IP address as a client on the specified port. Some TCP/IP modules (RPI and ESP8266) will accept a URL instead of an IP address. Returns: 0=Fail, 1=OK
Fc9-string-icon.png - STRING Address
IP address as a string e.g. "192.168.1.1" or URL on some TCP/IP modules
Fc9-u16-icon.png - UINT Port
Port number to connect to.
Fc9-comp-macro.png Receive
Attempts to receive up to a specified number of bytes from the active connection. Returns the number of bytes received.
Data Array to store the data into.
Fc9-u16-icon.png - UINT Count
Maximum number of bytes to read
Fc9-u16-icon.png - UINT Timeout
Maximum time to wait in mS (approx)
Fc9-comp-macro.png Send
Sends the specified number of bytes via the active connection. Returns the number of bytes sent, 0=Fail.
Array containing the data to send
Number of bytes to send from the data array
Fc9-comp-macro.png Listen
Bind the socket to a port on the local host and set to listen mode. First Open a Socket on the local host Returns: 0=Fail, 1=OK
Port number to listen on.
Fc9-comp-macro.png SocketOpen
Attempts to create a socket on the local device. This must be succesful to allow TCP/IP communications with a remote destination. Returns: 0=Fail / 1=OK
Fc9-comp-macro.png SocketClose
Closes the current socket connection
Fc9-comp-macro.png AcceptOpen
Required for systems where there can be multiple incoming threads Returns 1 if there is incoming comms requiring a new thread, else returns 0
Fc9-comp-macro.png AcceptClose
Goes with the AcceptOpen function to close the new thread handle.
Fc9-comp-macro.png Initialise
Initialises the network communications component.
Fc9-type-17-icon.png TCP/IP Component
Property to point to the TCP/IP or WIFI component you want to use. If unconnected then default to simulated TCP/IP network communications using the PC network adapter.
Fc9-type-16-icon.png TCP IP Channel
Allows for several parallel TCP/IP communications channels to be active at once by selecting unique TCP IP channels for each Network Comms component. Default 0.
Fc9-type-10-icon.png Status
Fc9-conn-icon.png Simulation
Fc9-type-16-icon.png Simulation Control
Allows the user to decide what happens when simulating. Simulation DLL forces all simulated TCP/IP comms to go directly via the simulation DLL bypassing any additional components. Component simulation forces the attached component to provide the simulation and maybe other aspects such as SPI/I2C communications.
Fc9-type-16-icon.png Network Interface
Some computers may have several network interfaces such as ethernet ports and wifi access. Select the correct network interface for the network you wish to connect to. Use the IP address to confirm you are connected to the right network.
Fc9-type-10-icon.png IP Address
IP Address of the selected network interface.
