Component: One Wire (DS2482) (Comms: Interface)
Revision as of 17:21, 9 November 2022 by Wiki bot (talk | contribs)
Author MatrixTSL
Category Comms: Interface
One Wire (DS2482) component
A One Wire master transciever controlled using I2C comms. Useful for microcontroller devices where One Wire communications timings are too tight to do reliably.
FREE
Fc9-comp-macro.png ReceiveByte
Fc9-comp-macro.png TransmitByte
Transmit a byte to the one wire bus a bit at a time
Fc9-u8-icon.png - BYTE Command
Fc9-comp-macro.png SkipROM
Performs a bus reset and the sends the SkipROM command byte
Fc9-comp-macro.png BusReset
Issue a 'ping' on the bus. If there is at least one sensor on the bus then it will generate a presence pulse. Returns 0 if a presense pulse was detected Returns 1 no device was detected
Fc9-comp-macro.png MatchROM
Performs a reset followed by the MatchROM code and then the 8-bit ROM code.
Fc9-u8-icon.png - BYTE FamilyCode
Fc9-u8-icon.png - BYTE SerialNumber
Fc9-comp-macro.png ScanBus
Scans the one wire bus to detect all connected devices. Returns the number of one wire devices found.
Fc9-comp-macro.png GetDeviceCount
Fc9-comp-macro.png GetIDByte
Returns byte ectet of the 64-Bit lasered ROM code, 255 on error
Fc9-u8-icon.png - BYTE Device
Device ID - Range: 0 - NumDevices - 1
Fc9-u8-icon.png - BYTE ByteIndex
Index of the data byte. 0=FamilyCode, 1-6=Serial, 7=CRC
Fc9-comp-macro.png Initialise
Fc9-type-21-icon.png Max Devices
Controls the maximum number of devices that can be detected during a ScanBus. For each additional device we require 8 bytes to store the ROM ID. Default: 8 = 64 Bytes of RAM
Fc9-conn-icon.png I2C Properties
Fc9-type-16-icon.png Device Address
Fc9-type-16-icon.png Channel
Channel selection
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Fc9-conn-icon.png Options
Baud rate to be used
Fc9-conn-icon.png Simulation
