Component: RC5 (EB060, Generic 36KHz) (Wireless)
Revision as of 17:21, 9 November 2022 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 1.2
Category Wireless
RC5 (EB060, Generic 36KHz) component
Low level routines for controlling a standard RC5 IR interface. Also available in the form of the EB060 RC5 E-block.
COMMSB
Receive Data
Example to receive data via RC5 encoded IR. RC5 incoming data pin connected to pin RB0. If a valid RC5 packet is received then the 8-bit data is shown on the PORTD pins and the 5-bit address data is shown on the PORTA pins. FC6 Icon.png RC5 Receive Example
Transmit Data
Example to send data via RC5 encoded IR. The transmission is done via the RC0 pin and the modulation is performed by the PWM output signal on the RC2 pin. The data and address values are incremented after each transmission. FC6 Icon.png RC5 Transmit Example
Schematic showing the required hardware to combine TX masking pin and PWM output pin.
Fc9-comp-macro.png CollectData
Retreives a value from the last successful RC5 reception. 0 = Read Command 1 = Read Address 2 = Read Toggle Bit
Fc9-u8-icon.png - BYTE selection
Fc9-comp-macro.png RXDisable
Disables the RC5 data receive functionality.
Fc9-comp-macro.png TXPacket
Transmits a RC5 data packet consisting of command, address and toggle bit.
Fc9-u8-icon.png - BYTE command
Command to send 0-63
Fc9-u8-icon.png - BYTE address
Address to send 0-31
Fc9-u8-icon.png - BYTE toggle
Toggle bit value 0-1
Fc9-comp-macro.png TXEnable
Enables the RC5 data transmit functionality.
Fc9-comp-macro.png CheckRx
Checks to see if a new RC5 packet has been received. Returns 0 to signify no new data available. Returns 1 to signify there is new data available.
Fc9-comp-macro.png TXDisable
Disables the RC5 data transmit functionality.
Fc9-comp-macro.png RXEnable
Enables the RC5 data receive functionality.
Fc9-type-21-icon.png IR Frequency
The infra-red modulation frequency used when transmitting a logic one.
Fc9-conn-icon.png Receive Properties
Fc9-type-16-icon.png Receive Mode
Specifies which receive mode the program should use.
Fc9-type-7-icon.png Invert Signal
Allows the incoming signal to automatically be inverted if needed by the receive hardware.
Fc9-type-16-icon.png Address Mask
What incoming values should we allow to make it through to the CheckRx macro.
Fc9-type-5-icon.png Receive Pin
Pin assigned to receive incoming RC5 data
Fc9-conn-icon.png Transmit Properties
Fc9-type-16-icon.png Transmit Mode
Specifies which transmit mode the program should use.
Fc9-type-10-icon.png Label
