Component: Robot Arm AllCode API (AllCode)
Revision as of 17:22, 9 November 2022 by Wiki bot (talk | contribs)
Category AllCode
Robot Arm AllCode API component
Matrix 5-axis Robot Arm with Gripper. Compatible with the Matrix Robot ARM Training Curriculum and Hardware. Features gripper pressure sensor, light sensor, colour sensor, Potentiometer, Magnetic sensor.
FREE
Fc9-comp-macro.png LEDOn
Switches on a single LED, LA0-LA7
Fc9-u8-icon.png - BYTE Index
0=LA0, 1=LA1, 2=LA2, 3=LA3, 4=LA4, 5=LA5, 6=LA6, 7=LA7
Fc9-comp-macro.png StoreCoords
Stores the provided coordinates as a position the ARM can recall.
Save Index - Range 0-29
Fc9-u8-icon.png - BYTE Position0
Range: 0-180
Fc9-u8-icon.png - BYTE Position1
Range: 0-180
Fc9-u8-icon.png - BYTE Position2
Range: 0-180
Fc9-u8-icon.png - BYTE Position3
Range: 0-180
Fc9-u8-icon.png - BYTE Position4
Range: 0-180
Fc9-comp-macro.png LCDClearLine
Fc9-u8-icon.png - BYTE Line
The line to clear, zero being the first (top) line of the display
Fc9-comp-macro.png LEDOff
Switches off a single LED, LA0-LA7
Fc9-comp-macro.png LEDWrite
Allows a value to be sent to control all eight LEDs LA0-LA7 at once
Fc9-u8-icon.png - BYTE Value
(0-63) 0b000000
Fc9-comp-macro.png GetAPIVersion
Gets the API version of the Robot ARM Firmware
Fc9-comp-macro.png GripperOpen
Fully opens the gripper at the end of the arm ready to pick something up.
Fc9-comp-macro.png KineSetXYZ
Sets the XYZ position and calculates the various servo motor angles required. Returns 0=Impossible, 1=InPosition
Fc9-s16-icon.png - INT X
Fc9-s16-icon.png - INT Y
Fc9-s16-icon.png - INT Z
Fc9-comp-macro.png ReadSwitch
Read the value of a single switch. Returns the value as a byte
Fc9-u8-icon.png - BYTE index
0=SA0, 1=SA1, 2=SA2, 3=SA3, 4=SA4, 5=SA5, 6=SA6, 7=SA7
Fc9-comp-macro.png LCDPrintStr
Fc9-string-icon.png - STRING PrintString
Enter the text or variable to print to the LCD
Fc9-comp-macro.png SetAllServos
Move all the servo positions between 0-180 Deg
Fc9-u8-icon.png - BYTE Servo0_Base
Position of servo0 in degrees (0-180)
Fc9-u8-icon.png - BYTE Servo1_Shoulder
Position of servo1 in degrees (0-180)
Fc9-u8-icon.png - BYTE Servo2_Elbow
Position of servo2 in degrees (0-180)
Fc9-u8-icon.png - BYTE Servo3_Wrist
Position of servo3 in degrees (0-180)
Fc9-u8-icon.png - BYTE Servo4_WristRotate
Position of servo4 in degrees (0-180)
Fc9-comp-macro.png ReadColourChannel
Reads a single colour channel from the value returned from the ReadColour macro.
0=Red, 1=Green, 2=Blue
Fc9-u16-icon.png - UINT Colour
Fc9-comp-macro.png Park
Parks the Robot ARM and switches off the servo motors
Fc9-comp-macro.png StorePosition
Stores the current position of the ARMs 5 axis.
Fc9-comp-macro.png ReadPressure
Read the value of the pressure sensor on the ARM gripper. Returns the value as a byte
Fc9-comp-macro.png GotoPosition
Recalls a previously saved position for the ARMs 5 axis.
Fc9-comp-macro.png MotorsMoving
Checks to see if any of the motors are still moving.
Fc9-comp-macro.png Beep
Allows the beeper to output a warning
Fc9-u8-icon.png - BYTE Iterations
Number of times to repeat
Fc9-u16-icon.png - UINT OnDelay
Delay in ms
Fc9-u16-icon.png - UINT OffDelay
Delay in ms
Fc9-comp-macro.png SetTrim
Allows minor adjustment on the 5 axis servo motors
Motor Index Range 0-4
Fc9-u8-icon.png - BYTE Trim
Amount of Trim Range 0-255, Default Value 128
Fc9-comp-macro.png SetServo
Move the specified servo motor position between 0-180 Deg
Range 0-4 : 0=Base, 1=Shoulder, 2=Elbow, 3=Wrist, 4=WristRotate
Position of servo in degrees (0-180)
Fc9-comp-macro.png GripperClose
Fully closes the gripper at the end of the arm ready to pick something up. Closes to a defined pressure using the built in pressure sensor. Returns 0 if nothing detected in the gripper Returns 1 if a valid object is detected
Fc9-u8-icon.png - BYTE Pressure
Range 1 - 100, Default Pressure = 20
Fc9-comp-macro.png KineGetXYZ
Calculates the current XYZ position from the current servo position coordinates
Range 0-2 : 0=X, 1=Y, 2=Z
Fc9-s16-icon.png - INT Return
Samples the Colour Sensor and reads the levels of Red, Green and Blue Light back as a 16-bit UINT variable. The colour format is 0b0BBBBBGGGGGRRRRR. The ReadColourChannel macro can be used to get individual channel colours.
Fc9-comp-macro.png LCDVerbose
Controls if the LCD is in user mode or verbose API mode,
Fc9-u8-icon.png - BYTE Mode
0=User Mode, 1=API Verbose Mode
Fc9-comp-macro.png LCDCursor
Fc9-u8-icon.png - BYTE X
Set the cursor position in the X plane, 0 is the left most cell (0-15)
Fc9-u8-icon.png - BYTE Y
Set the cursor position in the Y plane, 0 is the top most cell (0-1)
Fc9-comp-macro.png LCDPrintNum
Will allow you to print a number. This is limited to a signed-INT, -32768 to 32767
Fc9-s16-icon.png - INT Number
Fc9-conn-icon.png Operating Mode
Fc9-type-16-icon.png Mode
