Component: Modbus Master (SCADA) (Comms: System)
Revision as of 17:22, 9 November 2022 by Wiki bot (talk | contribs)
Version 2.1
Category Comms: System
Modbus Master (SCADA) component
Modbus component for talking to Modbus compatible hardware via RS232 or RS485.
SCADA
Fc9-comp-macro.png ReadHoldingRegister
This command requests the analogue holding register values starting from the start RegAddress and going through to RegAddress plus RegCount. Returns 0 for success, 1 for CRC fail and 255 for no reply.
Fc9-u16-icon.png - UINT SlaveID
The ID of the MODBUS slave
Fc9-u16-icon.png - UINT RegAddress
Address: 0=40001, 1=40002, ...
Fc9-u16-icon.png - UINT RegCount
Number of consecutive registers to read, starting from RegAddress
Fc9-comp-macro.png ReadCoil
This command requests the ON/OFF status of discrete coils starting from the start CoilAddress and going through to CoilAddress plus CoilCount. Returns 0 for success, 1 for CRC fail and 255 for no reply.
Fc9-u16-icon.png - UINT CoilAddress
Coil Address: 0=Coil1, 1=Coil2, 2=Coil3, ...
Fc9-u16-icon.png - UINT CoilCount
Number of consecutive coils to try and read
Fc9-comp-macro.png SetCoil
This command writes the contents of a discrete coil at the location CoilAddress. Returns 0 for success, 1 for CRC fail and 255 for no reply.
Fc9-u8-icon.png - BYTE CoilState
0=Off, 1=On
Fc9-comp-macro.png GetResponse
Collects as much incoming data as possible and stored into the response buffer. The number of bytes received will be stored into location 0 of the response buffer. Return value indicates validity of incoming CRC. 0 = OK, 1 = CRC fail, 255 = No Data
Fc9-comp-macro.png SetCoils
This command writes the contents of a series of discrete coils at the location starting at CoilAddress through to CoilAddress + CoilCount. Returns 0 for success, 1 for CRC fail and 255 for no reply.
Fc9-u8-icon.png - BYTE CoilData
An array of bytes each containing 8 1-bit coil values
Fc9-comp-macro.png GetResponseByte
Reads a byte from the last received response. The Index parametes specifies which byte to read back.
Fc9-u8-icon.png - BYTE Index
0=NumBytes, 1=SlaveAddress, 2=FunctionCode/ExceptionCode, 3=DataBytes, 4=data0, 5=data1, ..
Fc9-comp-macro.png ChangeFrameType
Default frame type is the type set in the component properties.
Fc9-u8-icon.png - BYTE Type
0 = Modbus RTU / 1 = Modbus ASCII
Fc9-comp-macro.png GetResponseInt
Reads a 16-bit value from the last received response. The Index parametes specifies the byte index of the value to read back.
4=data0, 6=data1, 8=data2, ..
Fc9-comp-macro.png SetHoldingRegisters
This command writes the contents of several holding registers starting at the location RegAddress through to location RegAddress + RegCount . Returns 0 for success, 1 for CRC fail and 255 for no reply.
Number of consecutive registers to write, starting from RegAddress
Fc9-u16-icon.png - UINT RegValue
Array of values to send to the registers
Fc9-comp-macro.png ReadAnalogInput
This command requests the analogue input register values starting from the start RegAddress and going through to RegAddress plus RegCount. Returns 0 for success, 1 for CRC fail and 255 for no reply.
Input Address: 0=10001, 1=10002, 2=10003, ...
Number of consecutive inputs to read, starting from RegAddress
This command writes the contents of a holding register at the location RegAddress. Returns 0 for success, 1 for CRC fail and 255 for no reply.
Value to send to the selected register
Fc9-comp-macro.png ReadDigitalInput
This command requests the ON/OFF status of discrete inputs starting from the start DataAddress and going through to DataAddress plus DataCount. Returns 0 for success, 1 for CRC fail and 255 for no reply.
Fc9-u16-icon.png - UINT DataAddress
Fc9-u16-icon.png - UINT DataCount
Fc9-comp-macro.png Initialise
Starts up the UART to allow communications
Fc9-conn-icon.png Modbus Properties
Fc9-type-16-icon.png Frame Type
Switches between RTU and ASCII forms of Modbus
Fc9-type-21-icon.png Receive Buffer Size
Fc9-type-21-icon.png Slave ID Bytes
Fc9-type-21-icon.png Silent Interval
Configures how much time to wait after each master modbus command before another command can be sent. A silent interval of 60ms minimum is required in order to guarentee successful reception of the next transmission. 0=No Delay 60 = 60mS - Default Range : 0 - 65535
Fc9-type-21-icon.png UART Receive Timeout
Amount of time to wait before timing out when listening for a slave's response. Range: 0 - 255. 0 = Don't Wait 1 - 254 = X ms 255 = Wait Forever
Fc9-type-21-icon.png Receive Timeout Count
Number of timeouts in a row to wait for until we decide the slave is not responding or finished responding to a message. Range: 0 - 255 0 = First Timeout Only 1 = First Timeout + 1 2 = First Timeout + 2
Fc9-conn-icon.png Runtime Properties
Fc9-type-10-icon.png Label
Fc9-type-21-icon.png Console Columns
Fc9-type-16-icon.png Data Source
Fc9-type-16-icon.png COM Port
Lists all the current available COM port hardware on your PC.
Fc9-type-7-icon.png Refresh Ports
Fc9-type-21-icon.png Baud Rate
COM port data rate in bits per second
