Component: Drawing Area (Graphical Color)
Revision as of 17:22, 9 November 2022 by Wiki bot (talk | contribs)
Version 1.6
Category Graphical Color
Drawing Area component
Simulation runtime only graphical display component designed for SCADA operations. Allows easy pixel based displays and support for the GLCD libraries such as bitmap drawer and textfield.
SCADA
Fc9-u8-icon.png - BYTE ScaleX
Fc9-u8-icon.png - BYTE ScaleY
Fc9-s16-icon.png - INT Number
Fc9-u16-icon.png - UINT X
Fc9-u16-icon.png - UINT Y
Fc9-u8-icon.png - BYTE Font
Fc9-comp-macro.png DrawLine
Fc9-u16-icon.png - UINT X1
Fc9-u16-icon.png - UINT Y1
Fc9-u16-icon.png - UINT X2
Fc9-u16-icon.png - UINT Y2
Fc9-u8-icon.png - BYTE Solid
Fc9-comp-macro.png Plot
Fc9-comp-macro.png DrawStart
Fc9-comp-macro.png DrawLineFast
Fc9-comp-macro.png FastPlot
Fc9-comp-macro.png BPlot
Fc9-comp-macro.png Window
Fc9-u8-icon.png - BYTE Red
Range: 0-255
Fc9-u8-icon.png - BYTE Green
Range: 0-255
Fc9-u8-icon.png - BYTE Blue
Range: 0-255
Fc9-comp-macro.png DrawCircle
Range: 0-255
Range: 0-255
Range: 0-255
Fc9-comp-macro.png Initialise
Fc9-conn-icon.png Dimensions
Fc9-conn-icon.png Colour
Fc9-conn-icon.png Bit Depth
Fc9-type-14-icon.png Colour Bit Depth
Fc9-conn-icon.png Fonts
Fc9-conn-icon.png Font 0
Fc9-conn-icon.png Simulation Mode
Fc9-type-16-icon.png Display Method
