Component: ACS7xx Current Sensor (Electrical)
Revision as of 17:22, 9 November 2022 by Wiki bot (talk | contribs)
Author medelec35
Category Electrical
ACS7xx Current Sensor component
ACS7XX range of +/- 5, 20, 30, 50, 100, 150 & 200A current sensors
SENSORS
Simple example showing how to use the simulation dial components as a meter display for use in monitoring type applications. FC6 Icon.png Meters
Fc9-comp-macro.png Current
Current reading in amps
Fc9-comp-macro.png VoltgeADC
Reads the Voltage of the ADC pin for diagnostic purposes. With no current flowing through the sensor, the voltage reading should be 2.50V. If that is out, then enter precise VDD within properties
Fc9-type-16-icon.png Device (Bidirectional)
Fc9-type-15-icon.png VDD
Fc9-type-6-icon.png Channel
