Component: Temp / Humidity (DHT22) (Environmental)
Revision as of 17:23, 9 November 2022 by Wiki bot (talk | contribs)
Version 1.2
Category Environmental
Temp / Humidity (DHT22) component
The DHT22 temperature and humidity sensor is a popular sensor allowing the ambient temperature and relative humidity to be monitored digitally. Humidity Range = 0% - 100% +/- 2% Temperature Range = -40 - 80 Degrees C +/- 0.5 Degrees C
SENSORS
Example Program showing how to sample the DHT22 sensor and show the temperature and humidity on an LCD. FC6 Icon.png DHT22 Example
Fc9-comp-macro.png GetTempWhole
Gets the whole number portion of the temperature returned by calling SampleSensor. If temperature is 15.8 degrees C then this function would return 15.
Fc9-s16-icon.png - INT Return
Fc9-comp-macro.png GetHumidityFloat
Gets the humidity returned by calling SampleSensor as a floating point number. If humidity is 15.8 % then this function would return 15.8.
Fc9-comp-macro.png GetTempString
Gets the temperature returned by calling SampleSensor as a string. If temperature is 15.8 degrees C then this function would return "15.8".
Fc9-comp-macro.png GetHumidityString
Gets the humidity returned by calling SampleSensor as a string. If humidity is 15.8 % then this function would return "15.8".
Fc9-comp-macro.png GetHumidityWhole
Gets the whole number portion of the humidity returned by calling SampleSensor. If humidity is 15.8 % then this function would return 15.
Fc9-comp-macro.png GetTempReal
Gets the real number portion of the temperature returned by calling SampleSensor. If temperature is 15.8 degrees C then this function would return 8.
Fc9-comp-macro.png GetHumidityReal
Gets the real number portion of the humidity returned by calling SampleSensor. If humidity is 15.8 % then this function would return 8.
Fc9-comp-macro.png SampleSensor
Communicates with the DHT22 sensor and receives the temperature and humidity readings. Returns 0 for success, 1 for no communication detected and 2 for checksum error.
Fc9-comp-macro.png GetTempFloat
Gets the temperature returned by calling SampleSensor as a floating point number. If temperature is 15.8 degrees C then this function would return 15.8.
Fc9-type-5-icon.png SIG Pin
Microcontroller I/O Pin connected to the DHT11 sensor data pin.
Fc9-type-7-icon.png Use Checksum
The checksum value is used to ensure the data being received is correct. Yes = Only receive data if checksum is correct No = Ignore checksum
Fc9-conn-icon.png Advanced Settings
Fc9-type-16-icon.png Clock Adjustment
On 8-bit PIC devices the timings can be a little tight as slower clock speeds and so we implement an adjustment factor to allow the sensor to function. Auto mode will attempt to automatically calculate a correct adjustment factor. Manual mode will allow you to set your own adjustment factor.
