Component: Quadrature Encoder (EBM007) (EBM Modules)
Version | 1.0 |
Category | EBM Modules |
Quadrature Encoder component
Provides a rotary encoder with dual digital outputs that provide rotation and direction information. When connected to two digital inputs of a microcontroller a “digital pot” can be implemented to convert to digital values.
SENSORS
This example scans the encoder for changes and displays a counter on the LCD based on the movement of the encoder.
CheckForChanges |
Polling function to check changes Returns 1 for chaged, 0 for no change, 255 for error | |
Return |
Disable |
Disables the use of the quad encoder Once this ist called, the read functions will return zeros until the next Enable() call | |
Return |
WriteCounter32 |
Sets the value of the internal count variable. Range: -2147483648 to 2147483647 | |
Value |
Return |
Enable |
Enables the use of the quad encoder If this is not called, the read functions will return zeros | |
Return |
ReadCounter |
Reads the current dial counter This is a counter from -32768 to 32767 | |
Return |
WriteCounter |
Sets the value of the internal count variable. Range: -32768 to 32767 | |
Value |
Return |
ResetCounter |
Resets the current dial counter to zero | |
Return |
ReadCounter32 |
Reads the current dial counter as a 32-bit value This is a counter from -2147483648 to 2147483647 | |
Return |
