Component: Temperature Infrared (Grove 101020062) (Environmental)
Revision as of 17:23, 9 November 2022 by Wiki bot (talk | contribs)
Version 1.2
Category Environmental
Temperature Infrared component
The Grove Infrared Temperature Sensor allows none contact measurement of temperatures ranging from -10 to 100 degrees C.
SENSORS
Fc9-comp-macro.png MeasureSurTemp
Measures the surrounding ambient temperature,
Fc9-comp-macro.png MeasureObjectTemp
Measures the temperature of the targetted object
Fc9-type-6-icon.png Ambient Pin (SUR)
Fc9-type-6-icon.png Object Pin (OBJ)
Fc9-conn-icon.png ADC Properties
Fc9-conn-icon.png Advanced Settings
Fc9-type-15-icon.png Temperature Calibration
Ambient temperature calibration value
Fc9-type-15-icon.png Temperature Range
Map of temperature-voltage according to sensor datasheet. 10 is the temperature step when sensor and object distance is 9CM.
Fc9-type-15-icon.png Offset Voltage
Voltage of mid level voltage after 5-10 mins to bring the sensor to ambient.
Fc9-type-21-icon.png Number of Samples
Number of samples to take to average out each reading. Default 10.
