Component: Gyroscope 3 Axis (L3G4200D) (Movement & Orientation)
Revision as of 17:23, 9 November 2022 by Wiki bot (talk | contribs)
Version 2.0
Category Movement & Orientation
Gyroscope 3-Axis component
Interface to the L3G4200D three axis digital gyroscope. Panel GUI can be used to simulate incoming data for testing.
SENSORS
Fc9-comp-macro.png GetZ
Returns the previously sampled Z axis data
Fc9-s16-icon.png - INT Return
Fc9-comp-macro.png GetY
Returns the previously sampled Y axis data
Fc9-comp-macro.png GetX
Returns the previously sampled X axis data
Fc9-comp-macro.png SampleDevice
Reads the Axis data from the device
Fc9-comp-macro.png ReadRegister
Read the data byte at the given address of the device
Fc9-u8-icon.png - BYTE Reg
address of the register to be read
Fc9-comp-macro.png WriteRegister
Writes the data byte to the given address of the device. Returns 0 if successful
address of register to be written with data byte
Fc9-u8-icon.png - BYTE Data
data byte to be written to device register
Fc9-comp-macro.png Initialise
Initialise the component.
Fc9-type-16-icon.png Output Data Rate
Fc9-type-16-icon.png Full Scale Selection
Specifies the maximum angular speed which the sensor can measure in degrees per second
Fc9-type-16-icon.png X Axis
Fc9-type-16-icon.png Y Axis
Fc9-type-16-icon.png Z Axis
Fc9-type-10-icon.png Label
Fc9-conn-icon.png Connection
Fc9-type-16-icon.png Channel
Channel selection
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Baud rate to be used
Fc9-conn-icon.png Simulation
Fc9-type-16-icon.png Simulate Comms
