Component: Barometer (MS5637) (Environmental)
Revision as of 17:23, 9 November 2022 by Wiki bot (talk | contribs)
Category Environmental
Barometer component
A small PCB surface mount barometric pressure sensor with a I2C bus interface. Pressure range 0 to 30 Bar. Temperature range -20 to +85 °C.
SENSORS
Fc9-comp-macro.png ReadPressureFloat
Reads the pressure as a floating point value in Bars. Resultion sets the return bit value and conversion time. Calls the ReadPressureRaw function and then converts to a meaningful value.
Fc9-u8-icon.png - BYTE Resolution
Range 0-5
Fc9-comp-macro.png Reset
Resets the device
Fc9-comp-macro.png ReadTemperatureFloat
Range 0-5
Fc9-comp-macro.png ReadPressureRaw
Reads the pressure as a digital 32-bit value. Resultion sets the return bit value and conversion time. 0=0.11mBar / 1=0.062mBar / 2=0.039mBar 3=0.028mBar / 4=0.021mBar / 5=0.016mBar
Range 0-5
Fc9-u32-icon.png - ULONG Return
Fc9-comp-macro.png ReadTemperatureRaw
Reads the temperature as a digital 32-bit value. Resultion sets the return bit value and conversion time. 0=0.012°C / 1=0.009°C / 2=0.006°C 3=0.004°C / 4=0.003°C / 5=0.002°C
Range 0-5
Fc9-comp-macro.png ReadPROM
Reads a single 16-bit value from the PROM calibration data.
Range 0-6
Fc9-comp-macro.png Initialise
Stes up the I2C bus and initialises the termperature sensor ready for use.
Fc9-conn-icon.png I2C Properties
Fc9-type-16-icon.png Channel
Channel selection
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Baud rate to be used
Fc9-conn-icon.png Simulation
