Component: Thermistor Template (Sensors)
Revision as of 17:23, 9 November 2022 by Wiki bot (talk | contribs)
Author Matrix
Category Sensors
Thermistor Template component
Base component for creating thermistors. Has no GUI - this would be added by concrete examples using this basem which may or may not expose the propertes.
SENSORS
This example simply reads the value from the thermistor sensor component and outputs the value to an LCD as a temperature in degrees C. FC6 Icon.png EBM003 Example
Fc9-comp-macro.png GetIntegerTemperature
Reads the ADC input and returns the calculated Temperature as Integer degrees C
Fc9-s16-icon.png - INT Return
Fc9-comp-macro.png SetChannel
Set the ADC Channel
Fc9-s16-icon.png - INT ChannelID
Fc9-comp-macro.png GetRealTemperature
Reads the ADC input and Returns the calculated Temperature as Float value in degrees C
Fc9-comp-macro.png CalculateTemperature
Converts the input ADC value and returns the Temperature in tenths of degree C
Fc9-u16-icon.png - UINT ADCValue
ADC Reading to be converted
Fc9-comp-macro.png GetADCValue
Returns the Raw ADC value from the Analogue Channel
Fc9-comp-macro.png SetTemperature
Simulation macro that sets the internal ADC value to the appropriate value for a given temperature. This allows all internal systems of the sensor to be simulated.
Fc9-f32-icon.png - FLOAT Temperature
The temperature in C - restricted to -25 to +125 range
Fc9-type-6-icon.png ADC Channel
The ADC channel to which the thermistor circuit is connected. It is assumed that the thermistor is connected between the ADC pin and 0V, with a fixed resistor connected between the ADC pin and +V.
Fc9-type-16-icon.png Wiring
Specifies the arrangement of the Thermistor and Fixed Resistor. Pull Down - Thermistor connected between ADC pin and GND, fixed resistor between ADC pin and VCC. Pull Up - Thermistor connected between ADC pin and VCC, fixed resistor between ADC pin and GND.
Fc9-type-21-icon.png ADC Bit Resolution
Fc9-type-21-icon.png Resistor Value
Value in Ohms of the pullup series resistor. i.e. The resistor is connected between the ADC pin and the positive supply rail.
Fc9-type-21-icon.png -25C Thermistor Value
Value in Ohms of the Thermistor at -25 deg C
Fc9-type-21-icon.png 0C Thermistor Value
Value in Ohms of the Thermistor at 0 deg C
Fc9-type-21-icon.png 25C Thermistor Value
Value in Ohms of the Thermistor at 25 deg C
Fc9-type-21-icon.png 50C Thermistor Value
Value in Ohms of the Thermistor at 50 deg C
Fc9-type-21-icon.png 75C Thermistor Value
Value in Ohms of the Thermistor at 75 deg C
Fc9-type-21-icon.png 100C Thermistor Value
Value in Ohms of the Thermistor at 100 deg C
Fc9-type-21-icon.png 125C Thermistor Value
Value in Ohms of the Thermistor at 125 deg C
