Component: TCP/IP (NM7010A) (Comms: Networking)
Revision as of 17:24, 9 November 2022 by Wiki bot (talk | contribs)
Version 2.0
Category Comms: Networking
TCP/IP component
TCP/IP component designed to work with the WIZ3100 range of modules from Wiznet. Also available in the form of the version 1 EB023 E-block which uses the NM7010A module.
COMMSA
Fc9-comp-macro.png InitialiseSim
Fc9-comp-macro.png TxSendMyIP
This macro fills the specified channel's transmit buffer with 4 bytes of data representing this Internet E-Block's IP address as specified in the component's property page.
Specifies the communications channel 0-3
Fc9-comp-macro.png TxSendString_Sim
This macro fills the specified channel's transmit buffer with data. It can fill the buffer with a string of information.
Data byte to append to Tx buffer.
Fc9-u8-icon.png - BYTE Length
Fc9-comp-macro.png RxReadHeader_Sim
A call to this macro will return a byte of data in the reception buffer of the specified channel. It will also internally increment a pointer to that data so that the next call to 'Rx_readbyte' (or any other read function) will read the next byte
Fc9-u8-icon.png - BYTE Idx
Fc9-comp-macro.png RxMatch_6_Bytes_Sim
This macro returns a non-zero value when the next 6 bytes of data in the specified channel's reception buffer are the same as those passed as parameters. There are similar functions that check for 2 bytes and 4 bytes.
Fc9-u8-icon.png - BYTE Byte1
Specifies the value of the first byte
Fc9-u8-icon.png - BYTE Byte2
Specifies the value of the second byte
Fc9-u8-icon.png - BYTE Byte3
Specifies the value of the third byte
Fc9-u8-icon.png - BYTE Byte4
Specifies the value of the fourth byte
Fc9-u8-icon.png - BYTE Byte5
Specifies the value of the fifth byte
Fc9-u8-icon.png - BYTE Byte6
Specifies the value of the sixth byte
Fc9-comp-macro.png RxMatchMyIP
This macro returns a non-zero value when the next 4 bytes of data in the specified channel's reception buffer are the same as the Internet E-block's IP address.
Fc9-comp-macro.png TxStart_Sim
This macro indicates the start of data transmission for the specified buffer. In TCP mode, data transmission can only begin once the socket has become established. In other modes, data transmission can occur as soon as the socket has been opened.
Fc9-comp-macro.png TCPClose_Sim
When an established TCP connection has finished transmission of data, either the local application (i.e. your code) or the remote application (i.e. the application at the other end of the connection) can initiate closure of the socket.
Fc9-comp-macro.png RxDataAvailable_Sim
This macro is used to check whether or not data has been received by the Internet E-Block. A return value of zero indicated that no data has been received. A positive return value indicates that data is available.
Fc9-comp-macro.png RxMatch_4_Bytes
This macro returns a non-zero value when the next 4 bytes of data in the specified channel's reception buffer are the same as those passed as parameters. There are similar functions that check for 2 bytes and 6 bytes.
Fc9-comp-macro.png SetMyIP
This macro sets up the Internet E-Block's own IP address. In most circumstances, this macro will not be required as the IP address setting in the component property page will remain constant throughout your application.
Fc9-u8-icon.png - BYTE IP0
First Byte of IP address
Fc9-u8-icon.png - BYTE IP1
Second Byte of IP address
Fc9-u8-icon.png - BYTE IP2
Third Byte of IP address
Fc9-u8-icon.png - BYTE IP3
Fourth Byte of IP address
Fc9-comp-macro.png SetDestination_Sim
This is used in IP and UDP modes to set the destination of the intended data transfer. The destination IP address needs to be set for both IP and UDP modes.
Fc9-u8-icon.png - BYTE Dst_IP0
Specifies the first byte of an IP address
Fc9-u8-icon.png - BYTE Dst_IP1
Specifies the second byte of an IP address
Fc9-u8-icon.png - BYTE Dst_IP2
Specifies the third byte of an IP address
Fc9-u8-icon.png - BYTE Dst_IP3
Specifies the fourth byte of an IP address
Fc9-u8-icon.png - BYTE Dst_Port_Hi
Port High Byte
Fc9-u8-icon.png - BYTE Dst_Port_Lo
Port Low Byte
Fc9-comp-macro.png TxSendMyMAC_Sim
This macro fills the specified channel's transmit buffer with 6 bytes of data representing this Internet E-Block's MAC address as specified in the component's property page.
Fc9-comp-macro.png RxSkipBytes_Sim
Often when receiving data packets, it may be necessary to ignore large sections of the data. This can be achieved by reading each byte individually (and ignoring the returned data), but a better way is to use this Rx_skipbytes macro.
Fc9-u8-icon.png - BYTE Count
Specifies how many bytes to skip
Fc9-comp-macro.png CreateIPSocket_Sim
Note that sockets on up to 4 channels can be simultaneously opened and these channels are numbered 0 to 3. Note that sockets with different modes can be opened on different channels.
Fc9-u8-icon.png - BYTE Protocol
Specifies which IP protocol to use
Fc9-u8-icon.png - BYTE Broadcast
Allows broadcast type packets to be sent and received
Once data in a particular channel has been received, the header will be filled with information about the received data. This macro will return the information in the header. The idx parameter specifies which byte of information in the header to read
Specifies the byte index to return
Fc9-comp-macro.png TxSendMyIP_Sim
Port High Byte
Port Low Byte
Fc9-comp-macro.png CreateTCPSocket_Sim
This macro creates a socket for sending and receiving TCP data.
Fc9-u8-icon.png - BYTE Src_Port_Hi
Port High Byte
Fc9-u8-icon.png - BYTE Src_Port_Lo
Port Low Byte
Fc9-comp-macro.png GetSocketStatus_Sim
This returns the state of the requested channel's socket.
Fc9-comp-macro.png TxEnd_Sim
Once the transmit buffer has been filled with data, call this macro to actually send the data.
Fc9-comp-macro.png RxReadString_Sim
A call to this macro will return a string of data in the reception buffer of the specified channel. It will also internally increment a pointer to that data so that the next call to 'Rx_readbyte' (or any other read function) will read the next byte
Fc9-comp-macro.png RxMatchMyIP_Sim
Fc9-comp-macro.png CreateMACSocket_Sim
This macro creates a socket for sending and receiving Ethernet data using raw data.
Fc9-u8-icon.png - BYTE Promiscuous
Receive everything (1) or just data bound for your MAC (0)
Allows broadcast messages to be accepted (1) or rejected (0)
Fc9-u8-icon.png - BYTE Error
Allowsmessages with errors to be accepted (1) or rejected (0)
Fc9-comp-macro.png TCPListen_Sim
This macro puts a previously opened TCP channel in "passive open" mode. This is the required mode when writing a TCP server application (e.g. a web server to display HTML web pages).
Fc9-comp-macro.png RxReadByte
Fc9-comp-macro.png CreateUDPSocket
This macro creates a socket for sending and receiving UDP data.
Port High Byte
Port Low Byte
Fc9-comp-macro.png TCPConnect_Sim
This macro puts a previously opened TCP channel in "active open" mode. This is the required mode when writing a TCP client application (e.g. using SMTP to send an email).
High Byte of destination port
Low Byte of destination port
Fc9-comp-macro.png RxMatch_2_Bytes
This macro returns a non-zero value when the next 2 bytes of data in the specified channel's reception buffer are the same as those passed as parameters. There are similar functions that check for 4 bytes and 6 bytes.
Port High Byte
Port Low Byte
Fc9-comp-macro.png TxSendByte
This macro fills the specified channel's transmit buffer with data. It can fill the buffer with a single byte of data, or with a string of information.
Fc9-u8-icon.png - BYTE Data
Fc9-comp-macro.png TxSendByte_Sim
Fc9-comp-macro.png RxFlushData
Once data reception has been completed, this macro should be called to discard the data packet and allow other data packets to be read.
Fc9-comp-macro.png RxReadByte_Sim
Fc9-comp-macro.png RxMatchMyMAC
This macro returns a non-zero value when the next 6 bytes of data in the specified channel's reception buffer are the same as the Internet E-block's MAC address entered in the component's property page.
Fc9-comp-macro.png RxFlushData_Sim
Fc9-comp-macro.png RxDataSize
This macro is used to detect the size of data collected by the Rx_data_available macro.
Fc9-comp-macro.png CreateUDPSocket_Sim
Port High Byte
Port Low Byte
Fc9-comp-macro.png RxMatch_4_Bytes_Sim
Fc9-comp-macro.png RxDataSize_Sim
Fc9-comp-macro.png RxMatch_2_Bytes_Sim
Fc9-comp-macro.png RxMatchMyMAC_Sim
Fc9-type-10-icon.png Label
Fc9-type-14-icon.png Max Channels
Fc9-type-14-icon.png I2C Address
Fc9-type-16-icon.png Channel
Channel selection
Baud rate to be used
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Fc9-type-5-icon.png Int Pin
Fc9-conn-icon.png Gateway IP
Fc9-type-14-icon.png Gateway0
Fc9-type-14-icon.png Gateway1
Fc9-type-14-icon.png Gateway2
Fc9-type-14-icon.png Gateway3
Fc9-conn-icon.png Subnet Mask
Fc9-type-14-icon.png Subnet0
Fc9-type-14-icon.png Subnet1
Fc9-type-14-icon.png Subnet2
Fc9-type-14-icon.png Subnet3
Fc9-conn-icon.png IP Address
Fc9-type-14-icon.png IP0
Fc9-type-14-icon.png IP1
Fc9-type-14-icon.png IP2
Fc9-type-14-icon.png IP3
Fc9-conn-icon.png MAC Address
Fc9-type-14-icon.png MAC0
Fc9-type-14-icon.png MAC1
Fc9-type-14-icon.png MAC2
Fc9-type-14-icon.png MAC3
Fc9-type-14-icon.png MAC4
Fc9-type-14-icon.png MAC5
Fc9-conn-icon.png Simulation
Fc9-type-7-icon.png Simulate I2C Comms
Fc9-conn-icon.png TCP Simulation
Fc9-type-16-icon.png Network Interface
List of network interfaces connected to the PC. Sets which interface we are communicating via.
Fc9-type-10-icon.png Hostname
Local PC's hostname
