Component: Timer (Storage)
Version | 1.1 |
Category | Storage |
Timer component
Allows you to measure the passage of time via the use of a hardware timer peripheral. Works like a stopwatch with macros to start, stop and reset the timer counter. Returns time as integer Seconds, Milliseconds, Microseconds and also Floating Point and String.
STORAGE
Here is a basic example showing the operation of the timer component used to time a section of code or the duration of a specific event.
GetCountSeconds |
Returns the count value as a number of whole seconds, rounded down to the nearest second | |
Return |
StartCounter |
Starts the timer counting. | |
ResetCounters |
Range: 0-1 where 0=Do Not Reset and 1=Reset | |
Return |
GetCountString |
Returns the count value as a floating point string in seconds. | |
Precision |
Number of decimal places to display in string | |
Return |
GetCountMicroSeconds |
Returns the count value as a number of whole microseconds, rounded down to the nearest microsecond | |
Return |
GetCountMilliseconds |
Returns the count value as a number of whole milliseconds, rounded down to the nearest millisecond | |
Return |
StopCounter |
Stops the timer counting. | |
Return |
ResetCounter |
Return |
GetCountReal |
Returns the count value as a floating point value in seconds. | |
Return |
GetRawCount |
Efficient command to collect the integer number of instructions since the timer was started. | |
Return |
