Component: USB MIDI (Comms: USB)
Revision as of 17:24, 9 November 2022 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 1.3
Category Comms: USB
USB MIDI component
Component to create and communicate using a standard MIDI connection. Compatible with simulation and USB enabled microcontroller devices. Currently only compatible with the 16-bit PIC range of devices.
COMMSC
Fc9-comp-macro.png SendMIDI
Sends a MIDI packet consisting of up to three bytes of information,
Fc9-u8-icon.png - BYTE Status
MIDI Status Byte - Used for commands such as NoteOn, NoteOff etc.
Fc9-u8-icon.png - BYTE Data1
MIDI Data Byte - Used as a parameter specific to the specified command
Fc9-u8-icon.png - BYTE Data2
Fc9-comp-macro.png SendPitchChange
Sends out a pitch change command on the specified channel.
Channel to send the pitch change to
Fc9-u16-icon.png - UINT Pitch_Change
New pitch value to use, Default 0x2000
Fc9-comp-macro.png SendNoteOff
Sends a note off command using the channel, note and velocity specified.
Fc9-u8-icon.png - BYTE Note
Fc9-u8-icon.png - BYTE Velocity
Fc9-comp-macro.png SendControl
Sends a control command using the channel, controller and value specified.
Fc9-u8-icon.png - BYTE Controller
Fc9-u8-icon.png - BYTE Value
Fc9-comp-macro.png SendNoteOn
Sends a note on command using the channel, note and velocity specified.
Fc9-comp-macro.png ReceiveMIDI
Waits for the time specified in the timeout parameter for an incoming MIDI message. Returns 0 to indicate a timeout, otherwise returns the first value from the MIDI message.
Fc9-u8-icon.png - BYTE Timeout
Fc9-comp-macro.png SendPolyPressure
Sends a note press with an associated polyphonic pressure value.
Fc9-u8-icon.png - BYTE Pressure
Fc9-comp-macro.png ReadData
Reads a byte from the last received MIDI message
Fc9-u8-icon.png - BYTE Idx
Byte to read 0-3
Fc9-comp-macro.png SendPatch
Fc9-u8-icon.png - BYTE Instrument
Fc9-comp-macro.png SendChannelPressure
Fc9-comp-macro.png Initialise
Starts up the USB communications and attempts to enumerate. Returns 0 for a successful startup or 255 for a enumeration timeout.
Fc9-conn-icon.png USB Properties
Fc9-type-14-icon.png Vendor ID
USB VID
Fc9-type-14-icon.png Product ID
USB PID
Fc9-type-10-icon.png Device Name
USB Device Name
Fc9-type-10-icon.png Manufacturer
USB Manufacturer
Fc9-type-14-icon.png Major Version
USB Major Version Number
Fc9-type-14-icon.png Minor Version
USB Minor Version Number
Fc9-type-7-icon.png Enumeration Timeout
Specifies if the enumeration (Initialise function) can timeout if taking too long.
Fc9-conn-icon.png Simulation
Fc9-type-10-icon.png Label
Text displayed on the I/O flasher comms component.
Fc9-type-16-icon.png Data Source
Simulation data source used to allow the component to connect to specific MIDI hardware or the the data injector components.
Fc9-type-16-icon.png MIDI Port
