Component: WAV Library File (Storage)
Revision as of 17:24, 9 November 2022 by Wiki bot (talk | contribs)
Category Storage
WAV Library File component
Allows WAV files to be played or recorded using a file component to provide the data. Complete with buffer to allow for uninterrupted playback when performing other tasks. Playback compatible with analogue outputs such as DAC or PWM. Recording compatible with analogue inputs such as a Microphone.
STORAGE
Simple playback example - allows a wav file to be streamed out using PWM. Repeats the playback in a loop.
FC6 Icon.png WAV Playback
Simple recording example - allows a wav file to be recorded from a microphone connected to an ADC input pin. Records for approx 10 seconds.
FC6 Icon.png WAV Record
Fc9-comp-macro.png StartPlayback
Start playing a WAV file from the SD card. Use the GetNextSample and EndOfFile macros to read out the contents of the file. Use the ProcessBuffer macro to maintain the local buffer. Returns 1 if file found and opened, else returns 0.
WAV Filename e.g. "Test.wav"
Fc9-comp-macro.png EndOfFile
A simple check to see if we are at the end of the file. Returns 0 if we and not yet at the end fo the file. Returns 1 if we are at the end of the file.
Fc9-comp-macro.png ProcessBuffer
When Playing a WAV File - Fills the local data buffer from the SD card. When Recording a WAV File - Writes the local data buffer to the SD card. Must be called often enough to maintain playback or recording. Returns 0 for buffer OK 1 for buffer overrun
Fc9-comp-macro.png StopRecording
Fc9-comp-macro.png PutNextSample
Writes the value for the next sample and auto increments the file pointer. Ideally this function should be called as part of a timer interrupt at the sample rate. The value written should be collected using an analogue input such as a Mic.
Fc9-u16-icon.png - UINT Sample
Fc9-comp-macro.png GetNumChannels
Returns the number of audio channels stored in the WAV file during playback.
Fc9-comp-macro.png StartRecording
Start recording a WAV file to the SD card. Use the WritetNextSample macro to write the contents of the file. Use the ProcessBuffer macro to maintain the local buffer. Returns 1 if file created and opened, else returns 0.
Fc9-u8-icon.png - BYTE BitsPerSample
Number of bits per sample - 8 or 16
Fc9-u32-icon.png - ULONG SampleRate
Sample Rate in Hz e.g. 8000 for 8KHz
Fc9-comp-macro.png GetBitsPerSample
Returns the number of bits per sample during playback.
Fc9-comp-macro.png GetNextSample
Retreives the value for the next sample and auto increments the file pointer. Ideally this function should be called as part of a timer interrupt at the sample rate. The value returned should be passed onto a means of analogue output e.g. a DAC or PWM.
Fc9-type-17-icon.png File Component
Pointer to the File component in your program that is responsible for providing the data to stream.
The number of RAM bytes to allocate to the WAV buffer. The buffer must be big enough to store enough WAV audio samples to maintain playback or recording when doing other program tasks or performing SD card read/write operations.
Fc9-type-16-icon.png Memory Type
