Component: FLASH (CAL) (Peripheral CAL)
Revision as of 17:24, 9 November 2022 by Wiki bot (talk | contribs)
Category Peripheral CAL
FLASH (CAL) component
CAL - Code Abstraction Layer A low level implementation giving direct access to Flash read and write routines.
FREE
Fc9-comp-macro.png WriteInstructionRow
Writes a complete row of instructions to the device memory. Takes the values from the data array.
Fc9-u32-icon.png - ULONG Address
Fc9-u32-icon.png - ULONG Data
Fc9-comp-macro.png ErasePage
Erase the minimum amount of flash (usually a page) at the selected address.
Start address of page
Fc9-comp-macro.png ReadInstruction
Reads a single instruction from the device memory. Loads the result into the Data array.
Writes a the minimum number of instructions to the device memory. Takes the values from the data array.
Fc9-comp-macro.png EraseAll
Erase all flash memory locations on the device.
Fc9-bool-icon.png - BOOL Aux
0=Primary Flash, 1=Aux Flash if available
Fc9-type-7-icon.png Enabled
Fc9-type-21-icon.png Type
Fc9-type-21-icon.png StartAddress
Fc9-type-21-icon.png Bits Per Instruction
Number of bits that can be stored or retreived using a single flash address
Fc9-type-21-icon.png Bits Per Value
Number of bits available when initialising the Flash memory.
Fc9-type-21-icon.png Min Write Count
Fc9-type-21-icon.png Row Instruction Count
Fc9-type-21-icon.png Page Instruction Count
Fc9-type-21-icon.png Program Counter Increment
Fc9-type-16-icon.png Family
