Component: Webserver (GENERIC Flash / File) (Comms: Networking)
Revision as of 17:25, 9 November 2022 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 1.5
Category Comms: Networking
Webserver (GENERIC - Flash / File) component
Webserver component designed to work with Network Comms abstraction layer. Provides a very simple interface to allow webpages to be hosted from hardware or simulation. Webpages can be embedded into ROM or can be pulled directly from a local file or a SD card via the File component. The File mode allows for images and other media to be served to the web client.
COMMSC
Webserver Embedded Files
A simple example demonstrating how to host a website with fixed HTTP content including dynamic sections that can be passed in and out of Flowcode SCADA.
For example a dynamic section could be used to display a variable value on a webpage such as a temperature or used to control Flowcode e.g. turn on an output.
FC6 Icon.png Webserver Embedded
Webserver Dynamic Files
Flowcode Embedded
A simple example demonstrating how to host a website with dynamic content based on external files including dynamic sections that can be passed in and out of an embedded system using an SD card and an ESP8266 module.
FC6 Icon.png ESP8266 Webserver FileSystem
ZIP Icon.png Webserver Files
Flowcode App Developer
A simple example demonstrating how to host a website with dynamic content based on external files including dynamic sections that can be passed in and out of Flowcode App Developer.
FC6 Icon.png Webserver FileSystem
Fc9-comp-macro.png GetInValueFloat
Returns the float value of an incoming Request parameter
Fc9-u8-icon.png - BYTE Index
Range: 0 to IncomingCount - 1
Fc9-comp-macro.png SetOutValueFloat
Sets one of the outgoing substitution values from a floating point value.
Range: 0 to OutgoingCount - 1
Floating point value to assign to the substitution
Fc9-u8-icon.png - BYTE NumDP
Number of decimal points to add
Fc9-comp-macro.png SetOutValueLong
Sets one of the outgoing substitution values from a numeric value.
Fc9-s32-icon.png - LONG Value
signed long integer value to assign to the substitution
Incoming string Index Range: 0 to Outgoing Count - 1
Fc9-string-icon.png - STRING Value
Value string to assign
Returns the string value of an incoming Request parameter
Incoming string Index Range: 0 to Incoming Count - 1
Fc9-comp-macro.png GetInValueLong
Returns the integer value of an incoming Request parameter
Fc9-comp-macro.png CreateServerSocket
Creates a listening socket on the selected port ready to accept incoming web page requests. Returns: 1 = OK / 0 = Listen Err / 255 = Socket Open Err
Fc9-u16-icon.png - UINT Port
Default HTTP port = 80
Fc9-comp-macro.png CheckSocketActivity
Checks for activity on the server socket and serves out the webpages to any requesting parties. Returns: URL string request, or null string if no activity has occured.
Fc9-comp-macro.png Initialise
Resets and initialises the Web Server component.
Fc9-type-10-icon.png Label
Fc9-type-21-icon.png RX Buffer Size
Fc9-type-17-icon.png Network Comms Component
Redirects communications via the selected component allowing different TCP/IP modules with different macros to work.
Fc9-conn-icon.png Source Files
Fc9-type-16-icon.png HTML Source
Sets the method for streaming data, we can either host it loacally using a property or refer to external files.
Fc9-type-14-icon.png Max Pages
Maximum number of pages we can serve using the embedded page type webserver. Currently limited to 4 pages.
Fc9-type-10-icon.png Name Page 1
Name of HTML page 1 - index.htm is the default page that will be presented.
Fc9-type-11-icon.png HTML Page 1
Embedded HTML code used for page 1
Fc9-type-10-icon.png Name Page 2
Name of HTML page 2
Fc9-type-11-icon.png HTML Page 2
Embedded HTML code used for page 2
Fc9-conn-icon.png Substitutions
Fc9-conn-icon.png Outgoing
Fc9-type-16-icon.png Count
Fc9-type-21-icon.png Length 0
Fc9-conn-icon.png Incoming
Fc9-type-21-icon.png Length 1
