Component: LCD (Grove UART) ()
Revision as of 17:25, 9 November 2022 by Wiki bot (talk | contribs)
Version 2.0
Category
LCD (Grove - UART) component
Standard alphanumeric LCD based on the Grove display module.
DISPLAYS
Fc9-comp-macro.png Clear
Fc9-comp-macro.png PrintString
Fc9-comp-macro.png PrintAscii
Fc9-u8-icon.png - BYTE character
Allows you to print a number. This is limited to a signed-INT, -32768 to 32767
Fc9-s16-icon.png - INT Number
Fc9-comp-macro.png BacklightControl
Fc9-u8-icon.png - BYTE State
0=Backlight Off, 1=Backlight On
Fc9-comp-macro.png ClearLine
Fc9-u8-icon.png - BYTE Line
Fc9-comp-macro.png Cursor
Fc9-u8-icon.png - BYTE x
Fc9-u8-icon.png - BYTE y
Fc9-comp-macro.png ScrollDisplay
Fc9-u8-icon.png - BYTE position
Number of positions to scroll the display
Fc9-u8-icon.png - BYTE direction
Direction to scroll the display: 0=Left, 1=Right
Fc9-comp-macro.png Start
Startup routine required by the hardware device.
Fc9-conn-icon.png LCD Configuration
Fc9-type-16-icon.png Rows
Fc9-type-16-icon.png Columns
Fc9-type-16-icon.png Channel
Fc9-type-5-icon.png TX
Fc9-type-7-icon.png Use RX
Selects if the Receive pin is used by the component. Yes: The RX pin is active and used to receive data for the UART. No: The RX pin is disabled and free to be used as general I/O.
Fc9-type-16-icon.png Baud Options
Fc9-conn-icon.png Simulation
Fc9-type-21-icon.png Console Columns
Fc9-type-16-icon.png Data Source
