Component: Nextion Display (Graphical Color)
Revision as of 17:25, 9 November 2022 by Wiki bot (talk | contribs)
Category Graphical Color
Nextion Display component
A simple libray to interface a Nextion display. The elements on the nextion display are built using the Nextion Editor software and uploaded to the display. The component can then interact with the display elements.
FREE
Handling Buttons
This example looks for button presses with IDs 1 and 2. On a button release event the corresponding LEDs will be toggled.
FC6 Icon.png Nextion Touch Demo
Fc9-comp-macro.png GetTouchID
Gets the ID of the corresponding touch event. Must be called after calling GetTouchEvent component macro.
Fc9-comp-macro.png GetValue
Gets the value from a specific item
Fc9-string-icon.png - STRING Name
Fc9-u32-icon.png - ULONG Return
Fc9-comp-macro.png SetText
Sets the text of a specific item
Fc9-comp-macro.png GetText
Gets the text of a specific item
Fc9-comp-macro.png SetFontColour
Sets the foreground font colour of a specific item
Fc9-u32-icon.png - ULONG Colour
Fc9-comp-macro.png SetPage
Sets the page of the display allowing multiple configurations
Name of the page e.g. "page0"
Fc9-comp-macro.png SetValue
Sets the numeric value of a specific item
Fc9-u32-icon.png - ULONG Number
Fc9-comp-macro.png GetTouchEvent
Collects the next touch event in the queue. Returns 0 for no touch event detected, 1= touch press, 2 = touch release
Sets the background colour of a specific item
Fc9-comp-macro.png Initialise
Sets up the UART connection to the Nextion display
Fc9-conn-icon.png Communications
Fc9-type-16-icon.png Channel
Fc9-type-16-icon.png Baud Options
Fc9-type-5-icon.png TX
Fc9-type-5-icon.png RX
Fc9-type-21-icon.png Touch Queue Size
Number of touch press/release events we can store before running out of memory.
Fc9-type-21-icon.png Receive Buffer Size
Sets the number of byte elements inside the circular buffer.
Fc9-type-21-icon.png Timeout
Time in milliseconds to wait for a reply to a command.
Fc9-conn-icon.png Simulation
Fc9-type-16-icon.png Data Source
Simulation data source used to allow the component to connect to various remote devices Nothing - Simulation data is ignored COM port - Routes the communication data to and from a physical or virtual COM port API - Routes the communication data via a data injector component on the Panel.
