Component: GLCD (EB076 v2) (EB076) (E blocks 1)
Revision as of 17:25, 9 November 2022 by Wiki bot (talk | contribs)
Version 2.0
Category E-blocks 1
GLCD (EB076 v2) component
Graphical display component designed to work with the Picaso range of displays from 4D Systems. Also available in the form of the EB076 GLCD Touchscreen E-block. Component based around the uLCD-32PTU display.
DISPLAYS
Fc9-comp-macro.png G4D_InitialiseCard
Checks to see if an SD card is inserted into the module. If the SD card is available then the card is initialised ready for use. Returns 0 for succesful initialisation or 255 for a detected failure.
Fc9-comp-macro.png G4D_DumpScreenToFilePicaso
Copies a section of the display to the micro SD card starting from X, Y and ranging to Width, Height.
Fc9-u16-icon.png - UINT X
Fc9-u16-icon.png - UINT Y
Fc9-u16-icon.png - UINT Width
Fc9-u16-icon.png - UINT Height
Assigns the name of the file on the card to store the data.
Fc9-comp-macro.png G4D_ReadTouchCoordinatesPicaso
Returns the coordinates of the last touch event. Axis = 0 or 'x' or 'X' - Returns the X coordinate. Axis = 1 or 'y' or 'Y' - Returns the Y coordinate.
Fc9-u8-icon.png - BYTE Axis
Fc9-comp-macro.png G4D_GetTouchCoordinatesPicaso
Reads the value of the last touchscreen input from the display. Returns a 0 if no new touch is detected. Returns a 1 if a press is detected. Returns a 2 if a release is detected. Returns a 3 if a moving drag is detected.
Fc9-s16-icon.png - INT Number
Fc9-u8-icon.png - BYTE Font
Size of the font - 0 = Normal, 1 = Double Width, 2 = Double Width and Height, 3 = Double Height
Fc9-comp-macro.png DrawLine
Fc9-u16-icon.png - UINT X1
Fc9-u16-icon.png - UINT Y1
Fc9-u16-icon.png - UINT X2
Fc9-u16-icon.png - UINT Y2
Fc9-comp-macro.png G4D_DisplayImageFromFilePicaso
Attempts to print an image from the micro SD card using the specified filename on the card. The image is printed at location starting from X, Y. PosH and PosL specify the sector address of the previously stored image icon.
Fc9-u16-icon.png - UINT OffsetHi
Upper 16-bit image offset within the 4D systems resource file, default = 0
Fc9-u16-icon.png - UINT OffsetLo
Lower 16-bit Image offset within the 4D systems resource file, default = 0
Fc9-comp-macro.png G4D_DisableTouchscreenPicaso
Disables the touchscreen interface if available.
Fc9-u8-icon.png - BYTE Solid
Fc9-comp-macro.png Plot
Fc9-comp-macro.png DisplayControl
Controls the operation, contrast and backlight on the display
Fc9-u8-icon.png - BYTE Backlight
0=Backlight Off, 1=Backlight On (default)
Fc9-u8-icon.png - BYTE Display
0=Display off, 1=Display on (default)
Fc9-u8-icon.png - BYTE Contrast
Contrast Range 1 - 15
Fc9-comp-macro.png FastPlot
Fc9-comp-macro.png G4D_EnableTouchscreenPicaso
Enables the touchscreen interface if available.
Fc9-comp-macro.png G4D_DisplayVideoFromCard
Attempts to display a sequence of images from the micro SD card at the specified address location on the card. The images are printed at location starting from X, Y and ranging to Width, Height.
Fc9-u8-icon.png - BYTE ColourMode
Specifes the colour depth setting - 0 = 8-bit colour, 1 = 16-bit colour.
Fc9-u8-icon.png - BYTE Delay
Specifies the number of milliseconds to wait in between displaying each image.
Fc9-u16-icon.png - UINT Frames
Specifies the number of frames to display.
Fc9-u8-icon.png - BYTE AddH
Fc9-u8-icon.png - BYTE AddM
Fc9-u8-icon.png - BYTE AddL
Fc9-comp-macro.png G4D_SetVolumePicaso
Sets the playback volume.
Fc9-u8-icon.png - BYTE Volume
Range 8-127, 8 = Minimum Volume Level / 127 = Maximum Volume Level
Fc9-comp-macro.png BPlot
Fc9-comp-macro.png Window
Fc9-comp-macro.png G4D_DumpScreenToCard
Copies a section of the display to the micro SD card starting from X, Y and ranging to Width, Height. The address parameters assign where on the card to store the data.
Fc9-comp-macro.png G4D_SetVGADisplaySizePicaso
Specifies the VGA display size in pixels. Size = 0 - 320 x 240 Resolution. Size = 1 - 640 x 480 Resolution. Size = 2 - 800 x 480 Resolution. Size = 3 - Custom Resolution
Fc9-u8-icon.png - BYTE Size
Fc9-comp-macro.png G4D_IsAudioPlayingPicaso
Checks to see if an audio file is currently playing. Returns 0 is no audio is currently playing. Returns 1 if there is audio playing.
Fc9-u8-icon.png - BYTE Red
Fc9-u8-icon.png - BYTE Green
Fc9-u8-icon.png - BYTE Blue
Fc9-comp-macro.png DrawCircle
Fc9-comp-macro.png G4D_DisplayImageFromCard
Attempts to print an image from the micro SD card at the specified address location on the card. The image is printed at location starting from X, Y and ranging to Width, Height.
Fc9-u16-icon.png - UINT Handle
Fc9-comp-macro.png G4D_SetTouchRegionPicaso
Specifies the area of the screen which will respond to touchscreen inputs.
Fc9-comp-macro.png G4D_PlayAudioFromFilePicaso
Attempts to stream an audio wav file from the micro SD card using the specified filename.
Fc9-u8-icon.png - BYTE Play_Option
Play_Option = 0 - Return when playing complete / 1 - Return immediatley / 2 - Stop Playback / 3 - Pause Playback / 4 - Resume Playback
Fc9-comp-macro.png Initialise
Fc9-conn-icon.png Dimensions
Fc9-conn-icon.png Colour
Fc9-conn-icon.png Bit Depth
Fc9-type-14-icon.png Colour Bit Depth
Fc9-type-16-icon.png Channel
Fc9-type-5-icon.png TX
Fc9-type-5-icon.png RX
Fc9-type-5-icon.png Reset Pin
I/O pin connected to the reset signal on the gLCD
Fc9-type-7-icon.png High Speed
Determines if the baud rate is automaticaly switched from 9600 baud on initialise to 57600 baud. Only available in hardware mode.
Fc9-type-16-icon.png Baud Options
Fc9-conn-icon.png Simulation Mode
Fc9-type-16-icon.png Display Method
Fc9-type-21-icon.png Console Columns
Fc9-type-16-icon.png Data Source
