Component: GLCD (ILI9163C) (Graphical Color)
Revision as of 17:25, 9 November 2022 by Wiki bot (talk | contribs)
Version 1.6
Category Graphical Color
GLCD (ILI9163C) component
Graphical display component designed to work with the ILI9163C 16-bit colour graphical controller IC.
DISPLAYS
Fc9-u8-icon.png - BYTE Font
Fc9-comp-macro.png BacklightOn
Sets the backlight enable pin allowing the display backlight to switch on. Switching the backlight on and off at high speed allow the light to be dimmed.
Fc9-u8-icon.png - BYTE ScaleX
Fc9-u8-icon.png - BYTE ScaleY
Fc9-s16-icon.png - INT Number
Fc9-u16-icon.png - UINT X
Fc9-u16-icon.png - UINT Y
Fc9-comp-macro.png DrawLine
Fc9-u16-icon.png - UINT X1
Fc9-u16-icon.png - UINT Y1
Fc9-u16-icon.png - UINT X2
Fc9-u16-icon.png - UINT Y2
Fc9-comp-macro.png Plot
Fc9-u8-icon.png - BYTE Solid
Fc9-comp-macro.png FastPlot
Fc9-comp-macro.png BacklightOff
Clears the backlight enable pin allowing the display backlight to switch off. Switching the backlight on and off at high speed allow the light to be dimmed.
Fc9-comp-macro.png BPlot
Fc9-comp-macro.png Window
Specifies a full screen or sub window of pixels to draw. Useful when used with the FastPlot function to draw bitmaps at high speed.
Fc9-u8-icon.png - BYTE Index
0=SpaceWidth, 1=PixelHeight
Fc9-u8-icon.png - BYTE Red
Fc9-u8-icon.png - BYTE Green
Fc9-u8-icon.png - BYTE Blue
Fc9-comp-macro.png DrawCircle
Fc9-comp-macro.png Initialise
Fc9-conn-icon.png Dimensions
Fc9-type-21-icon.png Offset X
Fc9-type-21-icon.png Offset Y
Fc9-conn-icon.png Colour
Fc9-conn-icon.png Bit Depth
Fc9-type-14-icon.png Colour Bit Depth
Fc9-type-5-icon.png Data
Data pin connection
Fc9-type-5-icon.png Clock
Clock pin connection
Fc9-type-5-icon.png Chip Select
Chip select pin connection
Fc9-type-5-icon.png A0
Fc9-type-5-icon.png Reset
Reset pin connection
Fc9-type-5-icon.png LED
Fc9-conn-icon.png Fonts
Fc9-conn-icon.png Font 0
Fc9-conn-icon.png Simulation Mode
Fc9-type-16-icon.png Display Method
