Component: GLCD (SSD1306) (SSD1306) (Graphical Monochrome)
Revision as of 17:26, 9 November 2022 by Wiki bot (talk | contribs)
Version 1.6
Category Graphical Monochrome
GLCD (SSD1306) component
Graphical display component based on the SSD1306 monochrome graphical controller IC.
DISPLAYS
Fc9-u8-icon.png - BYTE Font
Fc9-u8-icon.png - BYTE ScaleX
Fc9-u8-icon.png - BYTE ScaleY
Fc9-s16-icon.png - INT Number
Fc9-u16-icon.png - UINT X
Fc9-u16-icon.png - UINT Y
Fc9-comp-macro.png DrawLine
Fc9-u16-icon.png - UINT X1
Fc9-u16-icon.png - UINT Y1
Fc9-u16-icon.png - UINT X2
Fc9-u16-icon.png - UINT Y2
Fc9-u8-icon.png - BYTE Solid
Fc9-comp-macro.png Plot
Fc9-comp-macro.png BPlot
Fc9-u8-icon.png - BYTE Index
0=SpaceWidth, 1=PixelHeight
Fc9-u8-icon.png - BYTE PixelColour
0=White, 1=Black
Fc9-comp-macro.png DrawCircle
0=White, 1=Black
Fc9-comp-macro.png Initialise
Fc9-conn-icon.png Dimensions
Fc9-type-7-icon.png Interlaced
Fc9-type-21-icon.png Offset X
Fc9-type-21-icon.png Offset Y
Fc9-conn-icon.png Colour
Fc9-conn-icon.png Bit Depth
Fc9-type-14-icon.png Colour Bit Depth
Fc9-type-5-icon.png Chip Select (CS)
Chip select pin connection
Fc9-type-5-icon.png Read / Write (R/W)
Fc9-type-5-icon.png Reg Select (RS)
Fc9-type-5-icon.png Data (SD)
Fc9-type-5-icon.png Serial Clock (SCK)
Reset pin connection
Fc9-type-5-icon.png Reset (RST)
Fc9-conn-icon.png Fonts
Fc9-conn-icon.png Font 0
Fc9-conn-icon.png Simulation Mode
Fc9-type-16-icon.png Display Method
