Component: GLCD eINK (IL3829) (IL3829) (Graphical Monochrome)
Revision as of 17:26, 9 November 2022 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix Ltd |- | width="20%" style="color:gray;" | Version | 1.6 |- | width="20%" style="color:gray...")
Version 1.6
Category Graphical Monochrome
GLCD eINK (IL3829) component
Graphical display component based on the IL3829 monochrome graphical eINK controller IC. Functions without the use of a read pin by hosting the graphical memory using the microcontroller's RAM memory.
FREE
Font sizes
Standard Fonts
0 = Normal
1 = 2 x Width
2 = 2 x Width and 2 x Height
3 = 2 x Height
Extended Fonts
4 = 2 x Width and 3 x Height
5 = 2 x Width and 4 x Height
6 = 2 x Width and 5 x Height
7 = 2 x Width and 6 x Height
8 = 3 x width
9 = 3 x Width and 2 x Height
10 = 3 x Width and 3 x Height
11 = 3 x Width and 4 x Height
12 = 3 x Width and 5 x Height
13 = 3 x Width and 6 x Height
14 = 4 x width
15 = 4 x Width and 2 x Height
16 = 4 x Width and 3 x Height
17 = 4 x Width and 4 x Height
18 = 4 x Width and 5 x Height
19 = 4 x Width and 6 x Height
20 = 5 x width
21 = 5 x Width and 2 x Height
22 = 5 x Width and 3 x Height
23 = 5 x Width and 4 x Height
24 = 5 x Width and 5 x Height
25 = 5 x Width and 6 x Height
26 = 6 x width
27 = 6 x Width and 2 x Height
28 = 6 x Width and 3 x Height
29 = 6 x Width and 4 x Height
30 = 6 x Width and 5 x Height
31 = 6 x Width and 6 x Height
EBM001 Basic Example
EBM001 gLCD Example File
FC6 Icon.png EBM001 Example
EBM001 Maze Builder
FC6 Icon.png Maze Builder gLCD
FC6 Icon.png 3D Manipulations
Fc9-u8-icon.png - BYTE Font
Fc9-u8-icon.png - BYTE ScaleX
Fc9-u8-icon.png - BYTE ScaleY
Fc9-s16-icon.png - INT Number
Fc9-u16-icon.png - UINT X
Fc9-u16-icon.png - UINT Y
Fc9-comp-macro.png DrawLine
Fc9-u16-icon.png - UINT X1
Fc9-u16-icon.png - UINT Y1
Fc9-u16-icon.png - UINT X2
Fc9-u16-icon.png - UINT Y2
Fc9-u8-icon.png - BYTE Solid
Fc9-comp-macro.png Plot
Fc9-comp-macro.png BPlot
Fc9-u8-icon.png - BYTE Index
0=SpaceWidth, 1=PixelHeight
Fc9-comp-macro.png Refresh
Outputs the stored display data to the display
Fc9-comp-macro.png SetShadeIntensity
Allows the shade intensity to be set allowing for up to 15 different greyscale levels. Range: 1-15 Default: 15
Fc9-u8-icon.png - BYTE Shade
Range: 1-15 / 1=Dim / 15 = Bright
Fc9-u8-icon.png - BYTE PixelColour
0=White, 1=Black
Fc9-comp-macro.png DrawCircle
0=White, 1=Black
Fc9-comp-macro.png Initialise
Fc9-conn-icon.png Dimensions
Size of the required display buffer in Bytes
Fc9-conn-icon.png Colour
Fc9-conn-icon.png Bit Depth
Fc9-type-14-icon.png Colour Bit Depth
Fc9-type-5-icon.png Data Command (D/C)
Fc9-type-5-icon.png Data (SDI)
Serial data output control pin
Fc9-type-5-icon.png Chip Select (CS)
Chip select output control pin
Fc9-type-5-icon.png Serial Clock (CLK)
Serial clock output control pin
Fc9-type-5-icon.png Busy (BUSY)
Busy pin to determine if the display is busy or available for writes.
Fc9-conn-icon.png Fonts
Fc9-conn-icon.png Font 0
Fc9-conn-icon.png Simulation Mode
Fc9-type-16-icon.png Display Method
