Component: CNC Machine (Scenarios)
Jump to navigationJump to searchAuthor | Matrix |
Version | 1.0 |
Category | Scenarios |
CNC Machine component
A CNC Machine that allows for simulation movement in the X, Y, Z directions and also providing access to the Drill.
MODELS
Drill_Speed |
Will cause the drill to rotate according to the speed. If no speed is set it will stay static. | |
DrillSpeed |
Speed of the Drill. 0=Stopped | |
Return |
MoveToXYZ |
Moves the tool on the machine to the absolute X Y Z position specified at the speed specified by performing 3D linear interolation. | |
X |
Y |
Z |
Return |
HomeMachine |
Moves the machine an axis at a time until the end stop is hit. Finishes by resetting the coordinates to 0,0,0. | |
Return |
ResetCoordinates |
Resets the coordinates to the home position 0,0,0. | |
Return |
Initialise |
Enables the three motors within the component allowing for movement when any of the Axis macros are called. | |
Return |
Properties |
