Component: Airplane Landing Gear (Scenarios)
Revision as of 17:26, 9 November 2022 by Wiki bot (talk | contribs)
Category Scenarios
Airplane Landing Gear component
A simulation of an Airplane Landing Gear containing, switches, locking mechanisms and retracting landing gear.
MODELS
Airplane Landing Gear Scenario
Fc9-comp-macro.png FrontDoors
Will allow the front doors to open.
Fc9-u8-icon.png - BYTE Direction
Drops the door down or close them. 0 = Close 1 = Open
Fc9-comp-macro.png FrontDoorCloseSwitch
Test to see if the Front door will touch the collision switch by its original position. If it does, will return true. and stop movement. Assigned variable of a Bool is recommended
Fc9-comp-macro.png LandingGearDownSwitch
Test to see if the Landing Gear will touch the collision switch by its final position. If it does, will return true. and stop movement. Assigned variable of a Bool is recommended
Fc9-comp-macro.png RearDoorLocks
Will unlock or lock the rear doors
Fc9-u8-icon.png - BYTE OpenOrClose
Open =1 Close =0
Fc9-comp-macro.png LandingGearUpSwitch
Test to see if the Landing Gear will touch the collision switch above it. If it does, will return true. and stop movement. Assigned variable of a Bool is recommended
Fc9-comp-macro.png FrontDoorOpenSwitch
Test to see if the Back door will touch the collision switch by its final position. If it does, will return true. and stop movement. Assigned variable of a Bool is recommended
Fc9-comp-macro.png FrontDoorLocks
Will lock or unlock the front doors depending on the number given to the paremeter.
Open =1 Close=0
Retracts and drops the landing gear.
Drop the wheel down or retracts them. 0 = Retracts 1 = Drop
Fc9-comp-macro.png RearDoorCloseSwitch
Test to see if the rear door will touch the collision switch by its original position. If it does, will return true. and stop movement.
Fc9-comp-macro.png RearDoors
Will allow the rear door to open
Drop the door down or close them. 0 = Close 1 = Open
Fc9-comp-macro.png RearDoorOpenSwitch
Test to see if the rear door will touch the collision switch by its final position. If it does, will return true. and stop movement.
