Component: DC Motor ()
Revision as of 17:26, 9 November 2022 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 1.2
Category
DC Motor component
DC Motor that can be driven in one or both directions using digital output pins, PWM or HBRIDGE peripherals.
MECHATRONICS
Simple example showing how to drive the motor components and how to create sub assemblies attached to the motor output shafts in the simulation panels. FC6 Icon.png Motors
Fc9-comp-macro.png Coast
Turn off power to the motor by setting the pins according to the 'Coast Pattern' property.
Fc9-comp-macro.png Break
Actively drives both ends of the motor by setting the pins according to the 'Brake Pattern' property.
Fc9-comp-macro.png Disable
Disable the motor output
Fc9-comp-macro.png Forwards
Set the motor turning in the forwards direction by setting the pins according to the 'Reverse Pattern' property.
Fc9-u16-icon.png - UINT Duty
Sets the motor power for PWM or H-Bridge outputs
Fc9-comp-macro.png Enable
Enables the motor output
Fc9-comp-macro.png Reverse
Set the motor turning in the reverse direction by setting the pins according to the 'Reverse Pattern' property.
Fc9-conn-icon.png Control Type
Fc9-type-16-icon.png Control Method
Controls how the motor is controlled. On/Off requires output pins PWM requires a hardware PWM channel H-Bridge requires a hardware H-Bridge channel
Fc9-type-16-icon.png Bridge Type
Fc9-type-16-icon.png Enable Method
Decides how the motor outputs are enabled.
Fc9-conn-icon.png PWM Settings
Fc9-type-16-icon.png Channel
PWM Channel selector
Fc9-type-16-icon.png Alt Pin Enable
Alternative Pin Enable (if available on target device)
Fc9-type-5-icon.png Port
Fc9-type-14-icon.png Period Register
PWM Period Register value
Fc9-type-16-icon.png Prescaler Divide
Prescaler Divider value
Fc9-type-16-icon.png PWM Timer
Timer associated with PWM to drive the output. Warning - All PWM channels linked to the same timer will share the same period and prescaler settings.
Fc9-type-15-icon.png Frequency (KHz)
Fc9-type-5-icon.png Direction Pin
Fc9-conn-icon.png Simulation Settings
Fc9-type-15-icon.png Speed
Speed of the motor when turned on. Positive speed -> Counter-clockwsie Negative speed -> Clockwise
Fc9-type-15-icon.png Acceleration
Speed change per second when the motor us powered. Set to zero for instantaneous speed changes.
Fc9-type-15-icon.png Deceleration
Speed change per second when the motor is coasting with no power. Set to zero for instantaneous speed changes.
Fc9-type-7-icon.png Show Actuator
When active, an actuator is shown on the motor spindle to make the animation easier to observe.
Fc9-type-16-icon.png Forwards Direction
Which way the motor will rotate when the 'forwards' command is sent.
Fc9-conn-icon.png Linkage
Fc9-type-17-icon.png Target Object
An object or group to link the motor to - the object will move along with the motor.
