Component: Solenoid DC ()
Revision as of 17:26, 9 November 2022 by Wiki bot (talk | contribs)
Version 1.2
Category
Solenoid DC component
Simple open frame solenoid based on the Benson BDC.4 series.
MECHATRONICS
A solenoid will likely require more current than a microcontroller device can supply to activate the mechanical mechanism.
To amplify the current from the microcontroller simply use a NPN transistor or N channel FET.
The diode is required as with any inductive loads to help protect the microcontroller from back EMF generated by the inductor as the control signal switches the current through the inductor on and off
If the solenoid requires a large DC voltage, say 12V then you can connect the 12V directly to the top of the solenoid as shown above rather than using VCC or VDD. The transistor / FET will protect the micro from the large Voltage.
Fc9-conn-icon.png Connection
Fc9-type-5-icon.png Pin
Chip pin to connect the solenoid circuit to. NB) Solenoid cannot be moved unless there is a valid connection.
Fc9-conn-icon.png Simulation
Fc9-type-17-icon.png Target
A panel object to attach the solenoid to
Fc9-type-15-icon.png Stroke
The distance that the plunger extends when activated.
Fc9-type-21-icon.png Time (ms)
The time taken for the solenoid to move between the on and off positions. Used only for the purpose of System Panel animations on screen.
