Component: DAC (AD5662) (Analog Output)
Revision as of 17:27, 9 November 2022 by Wiki bot (talk | contribs)
Category Analog Output
DAC (AD5662) component
16-bit external DAC connected to the microcontroller using SPI.
COMMSA
Overview
The AD5662 is a 3V/5V general purpose SPI compatible, high-resolution digital to analog converter (DAC), capable of generating a rail-to-rail voltage output.
With 16-Bit resolution, the AD5662 is capable of finely tuning the voltage output across 65,536 steps, with an individual step voltage of 5/65536 = 0.0000763 volts DC.
The AD5662 requires an external reference voltage to set the output range of the DAC.
Pin reference from the datasheet:
Circuit Diagram
This example reads a potentiometer that is connected across the supply voltage. The output from the DAC should mimic the voltage that's across ADC pin & GND.
FC6 Icon.png AD5662_Demo
Fc9-comp-macro.png OutputDAC
Outputs a value to the DAC,
Fc9-u16-icon.png - UINT Output
Range: 0-65535 / 0=0V / 65535=VCC
Fc9-comp-macro.png Initialise
Initialise the SPI bus ready for communications,
Fc9-conn-icon.png SPI Properties
Fc9-type-16-icon.png Channel
SPI Channel selector
Fc9-type-16-icon.png Prescale
Prescale option selector
Fc9-type-5-icon.png MOSI
Fc9-type-5-icon.png MISO
Fc9-type-5-icon.png CLK
Fc9-type-5-icon.png CS / SS
Fc9-conn-icon.png Simulation
Fc9-type-7-icon.png Data Recorder Trace
