Component: PWM (Internal) (General Output)
Revision as of 17:27, 9 November 2022 by Wiki bot (talk | contribs)
Version 2.1
Category General Output
PWM (Internal) component
Pulse Width Modulation, a versitile way of generating a digital pulse using mark / space modulation. Uses the capture compare peripherals onboard most Microcontrollers to generate accurate waveforms without any intervention from the processor. Useful for generating audio, controlling the speed of motors, brightness of LED etc.
BASICIO
Here is a basic example to control the PWM duty based on an ADC reading.
FC6 Icon.png PWMDemo
Digital PWM trace
Here is another basic example which ramps the PWM duty cycle up and down. If the PWM output pin is connected to a LED and series resistor then the LED will smoothly transition between on bright and off.
FC6 Icon.png PWM Fader
Fc9-comp-macro.png ChangePeriod
Sets the overall period and prescaler of the output PWM signal.
Fc9-u16-icon.png - UINT Period
The maximum number that will represent 100% on, PIC/AVR: 0-255 16-bit PIC: 0-65535
Fc9-s16-icon.png - INT Prescaler
The scaler used to divide the system clock speed down to the PWM rate.
Fc9-comp-macro.png Disable
Disables a PWM channel and allows the default output / input state to be resumed
Fc9-comp-macro.png SetDutyCycle
Sets the PWM duty cycle in terms of on/off based on the current period setting. E.g. if period = 255 then duty of 128 is equal to 50% on and 50% off. 16-bit PIC users should use the 10bit duty function to access the full range.
Fc9-u8-icon.png - BYTE Duty
8-bit PWM duty 0-255
Fc9-comp-macro.png Enable
Enables a PWM channel as an output overriding the default output pin state.
Fc9-comp-macro.png SetFrequency
Sets a PWM of the specifed frequency at a duty of 50% Ideal use is a frequency generator
Fc9-u32-icon.png - ULONG Frequency
Enter frequency in Hz
Fc9-comp-macro.png SetDutyCycle10Bit
PIC/AVR - Sets the full scale PWM duty cycle based on the current period setting. If period = 255 then Duty of 512 is equal to 50%. 16-bit PICs have a 16-bit period range available. If period = 65535 then Duty of 32768 is equal to 50%.
Fc9-u16-icon.png - UINT Duty
PWM duty PIC/AVR: 0-1023 16-bit PIC: 0-65535
Fc9-type-16-icon.png Channel
Selects which PWM channel the component is connected to.
Fc9-type-7-icon.png Alternative pin
Allows an alternate pin to be used if available. Note that on some devices you will also have to change this setting in the device configuration.
Fc9-type-5-icon.png PWM Pin
Specifies the pin assigned to the PWM channel selected
Fc9-type-16-icon.png Remap Pin
Allows the PWM hardware pin to be reassigned to another pin
Fc9-conn-icon.png PWM Frequency
Fc9-type-16-icon.png PWM Timer
Timer associated with PWM to drive the output. Warning - All PWM channels linked to the same timer will share the same period and prescaler settings.
Fc9-type-21-icon.png Period Overflow
Allows the user to change the number of counts for the whole PWM period. Note that all PWM channels based on the same timer will share the same period overflow. PIC/AVR Range: 0 - 255 16-bit PIC Range: 0 - 65535
Fc9-type-16-icon.png Prescaler
Allows the user to change the number of program cycles per PWM cycle count. Note that all PWM channels based on the same timer will share the same prescaler.
Fc9-type-15-icon.png Period (us)
Displays the length of time to complete one PWM cycle.
Fc9-type-15-icon.png Frequency (Hz)
Fc9-type-15-icon.png Frequency (KHz)
Displays the frequency of PWM cycles per second.
Fc9-conn-icon.png Calculations
Fc9-type-15-icon.png Required Frequency (Hz)
Type in your required frequency in Hz and the component will automatically calculate the best prescaler and period to acheive the frequency with the maximum possible resolution.
Fc9-type-15-icon.png Calculated Frequency (Hz)
The frequency we have ended up acheiving using the calculated period and prescaler
Fc9-type-21-icon.png Calculated Period
The suggested period setting to use to acheive the calculated frequency.
Fc9-type-21-icon.png Calculated Prescaler
The suggested prescaler setting to use to acheive the calculated frequency.
Fc9-type-7-icon.png Apply To Defaults
Applies the calculated period and prescaler settings to the PWM component default settings.
Fc9-conn-icon.png Simulation
Fc9-type-16-icon.png Representation
Edits how the PWM is shown on the simulation panel.
