Component: Switch (Push, PCB, SMT) ()
Revision as of 17:28, 9 November 2022 by Wiki bot (talk | contribs)
Version 1.2
Category
Switch (Push, PCB, SMT) component
Surface mount click switch, standard 6mm square size.
FREE
Here is an example Flowcode program to read the value of a switch. FC6 Icon.png Switch
(5V / 11K) * 10K = 4.54545V
Fc9-type-5-icon.png Connection
Chip pin to which this switch is connected.
Fc9-type-16-icon.png Polarity
Sets whether activating the switch will take the chip pin high or low.
Fc9-type-14-icon.png Debounce (ms)
Time in milliseconds allowed for the switch state to stabilise after a change of state. NB) Debouncing is only used when reading the switch state using the component macros. Chip pin is NOT debounced.
