Component: Switch (Slide, PCB) ()
Author | Matrix Ltd |
Version | 1.2 |
Category |
Switch (Slide, PCB) component
Subminiature slide switch with black tang, PCB mount.
FREE
Switch
(5V / 11K) * 10K = 4.54545V
