Component: Switch Array (Slide) (Switches)
Revision as of 17:28, 9 November 2022 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 2.0
Category Switches
Switch Array (Slide) component
An array of up to eight slide switches, each connected to a single pin of the specified port.
BASICIO
Here is an example Flowcode program to read the values of a switch array. FC6 Icon.png Switch Array
(5V / 11K) * 10K = 4.54545V
Fc9-comp-macro.png ReadState
Read the state of the switch at the given index.
Fc9-u8-icon.png - BYTE Index
The switch to read the status of.
Fc9-comp-macro.png WaitUntilHigh
Pause the program until the switch at the given index is turned on.
Index of the switch to wait for.
Fc9-comp-macro.png ReadAll
Reads all of the switches at once, returning a byte containing one bit per switch.
Fc9-comp-macro.png GetHandle
Retrieves the object handle of the switch component at the given index.
Fc9-comp-macro.png WaitUntilLow
Fc9-type-16-icon.png Count
The number of LEDs in the array from 1 to 8.
Fc9-type-16-icon.png Input Mode
Choose a single port for all LEDs - pins are allocated in sequence from pin 0 - 7 ...or choose 'Custom pins' to assign each switch individually.
File:Fc9-type-19-icon.png Port
Fc9-type-16-icon.png Polarity
Active High = LEDs light when the chosen chip pin is ON Active Low = LEDs light when the chosen chip pin is OFF
Fc9-type-14-icon.png Debounce
Time in milliseconds allowed for the pin to settle following a change of state.
Fc9-type-16-icon.png Operation
Sets whether switches toggle or are press/release. NB) This option can only be set when the original target includes this option.
Fc9-conn-icon.png Simulation
Fc9-type-16-icon.png Alignment
Which 3D axis to align the copies along.
Fc9-type-15-icon.png Spacing
The distance between LEDs in the array. LEDs will be spaced symmetrically around the component centre. Use a negative value to reverse the order of the LEDs.
Fc9-type-7-icon.png Reverse
Whether to reverse the order of the switches.
Fc9-type-16-icon.png Show Labels
Whether to show labels giving each switch's pin connection.
Fc9-type-1-icon.png Label color
Color of the port and pin labels
