Component: CSV Read/Write (Runtime Tools)
Revision as of 12:12, 16 November 2022 by BenR (talk | contribs) (→‎Examples)
Category Runtime Tools
CSV Read/Write component
A component to simplify the task of creating and dumping data to a CSV file that can be loaded into Microcoft Excel or LibreOffice Math to create nice charts and graphs.
FREE
Simple example file to generate a two column CSV file that can be loaded into Microsoft Excel or LibreOffice Math.
CSV Component used with Embedded -> File SD component: FC6 Icon.png CSV Test
CSV Component used with Embedded -> File RPI component: FC6 Icon.png CSV Test RPI
CSV Component used with App Developer -> File component: FC6 Icon.png CSV Test AD
The component requires linking to a File component to provide access to the file system for simulation and runtime, this could be the File SD, File RPI or File AppDeveloper components.
Fc9-comp-macro.png CloseFile
Closes the file and finishes off any pending writes ready for use in an external application.
Fc9-comp-macro.png SequentialReadString
Reads the contents of a cell as a string. Automatically moved to the next data cell after a read.
Fc9-comp-macro.png AddString
Adds a string to the CSV followed by a comma. This will form a single column of data in the CSV file.
Fc9-string-icon.png - STRING data
Fc9-comp-macro.png ReadAsString
Fc9-u16-icon.png - UINT Column
Fc9-u16-icon.png - UINT Row
Fc9-comp-macro.png SequentialReadNumber
Reads the contents of a cell as a number. Automatically moved to the next data cell after a read.
Fc9-comp-macro.png AddNumber
Adds a number to the CSV followed by a comma. This will form a single column of data in the CSV file.
Fc9-f32-icon.png - FLOAT data
Fc9-comp-macro.png ReadAsNumber
Fc9-comp-macro.png SetSequentialIndex
Sets the index for sequential reads. Index is automatically reset to 0 after a file open.
Fc9-u16-icon.png - UINT Index
Fc9-comp-macro.png OpenFile
Creates or opens a file ready for streaming data. If the file already exists then the contents will be deleted and the file started again from scratch. Returns 1 if file found and opened.
Fc9-bool-icon.png - BOOL Erase
0=Append existing data, 1=Reset file data
Fc9-comp-macro.png NextRow
Move to the next row in the file
Fc9-type-20-icon.png Filepath
Sets the path of the file to write to. $(srcdir) default sets the path to be the same as the Flowcode project path.
