Component: Potentiometer (Panel) ()
Revision as of 08:37, 21 December 2022 by MartinW (talk | contribs) (→‎Potentiometer (Panel) component)
Version 1.4
Category
Analogue potentiometer with chicken head style pointer.
Note: The default Vref properties for AVR/Arduino is AREF. If there is no voltage being applied to the AREF pin, then you must change Vref option from AREF to AVCC
BASICIO
FC6 Icon.png Potentiometer Example
Fc9-conn-icon.png Simulation
Fc9-type-15-icon.png Start Angle
Fc9-type-15-icon.png Sweep Angle
Fc9-type-7-icon.png Retain Value
If yes is slected After saving your project, the ADC value will be retained when your project is reloaded.
Fc9-type-6-icon.png Channel
Fc9-conn-icon.png Settings
