Component: Accel / Mag 6 Axis (LSM303DLHC) (Movement & Orientation)
Version 2.0
Category Movement & Orientation
Accel / Mag 6-Axis component
LSM303DLHC Combined 6-Axis Accelerometer and Magnetometer sensors Useful for working out data such as Pitch and Yaw.
SENSORS
Fc9-comp-macro.png SimReset1G
Fc9-comp-macro.png Write_Register
Writes a data value to a specific register on the accelerometer
Fc9-u8-icon.png - BYTE Reg
Fc9-u8-icon.png - BYTE Data
Fc9-comp-macro.png UpdateCompassData
Reads from the compass and updates the local XYZ variables. Returns 1 for new data and 0 for no new data
Fc9-comp-macro.png SimSetAccelerometer
Allows the XYZ slider values to be set via the simulation
Fc9-s16-icon.png - INT X
Fc9-s16-icon.png - INT Y
Fc9-s16-icon.png - INT Z
Fc9-comp-macro.png CollectXYZData
Collect the data from the local accelerometer buffers. The Axis parameter specifies the Axis to be read. 0 / 'x' / 'X' - X axis 1 / 'y' / 'Y' - Y axis 2 / 'z' / 'Z' - Z axis
Fc9-u8-icon.png - BYTE Axis
Fc9-s16-icon.png - INT Return
Fc9-comp-macro.png UpdateAccelerometerData
Reads from the accelerometer and updates the local XYZ variables. Returns 1 for new data and 0 for no new data
Fc9-comp-macro.png SimSetCompass
Fc9-comp-macro.png Initialise
Sets up up the communication bus and initialises the accelerometer module. Returns 0 for success and > 0 for fail.
Fc9-conn-icon.png Sensor Options
Fc9-type-16-icon.png Power Mode
Fc9-type-16-icon.png Accel Data Rate
Fc9-type-16-icon.png Accel Scale
Fc9-type-16-icon.png Compass Data Rate
Fc9-type-16-icon.png Compass Scale
Fc9-type-16-icon.png Comms Mode
Specifies the communications mode. Interrupt - Wait for the interrupt pin to go high before allowing new data to be sampled. Polling - New data is sampled without needing to check the interrupt pin.
Fc9-type-16-icon.png Channel
Channel selection
Baud rate to be used
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Fc9-conn-icon.png Simulation
Fc9-type-16-icon.png Sim Type
Controls how the simulation data is generated, via the component GUI or via a I2C API.
Fc9-conn-icon.png I2C
Fc9-type-16-icon.png API
