Component: Airplane Landing Gear (Scenarios)
Version | 1.0 |
Category | Scenarios |
Airplane Landing Gear component
A simulation of an Airplane Landing Gear containing, switches, locking mechanisms and retracting landing gear.
MODELS
Airplane Landing Gear Scenario
FrontDoors |
Will allow the front doors to open. | |
Direction |
Drops the door down or close them. 0 = Close 1 = Open | |
Return |
RearDoorLocks |
Will unlock or lock the rear doors | |
OpenOrClose |
Open =1 Close =0 | |
Return |
LandingGearUpSwitch |
Test to see if the Landing Gear will touch the collision switch above it. If it does, will return true. and stop movement. Assigned variable of a Bool is recommended | |
Return |
FrontDoorLocks |
Will lock or unlock the front doors depending on the number given to the paremeter. | |
OpenOrClose |
Open =1 Close=0 | |
Return |
LandingGear |
Retracts and drops the landing gear. | |
Direction |
Drop the wheel down or retracts them. 0 = Retracts 1 = Drop | |
Return |
RearDoorCloseSwitch |
Test to see if the rear door will touch the collision switch by its original position. If it does, will return true. and stop movement. | |
Return |
RearDoors |
Will allow the rear door to open | |
Direction |
Drop the door down or close them. 0 = Close 1 = Open | |
Return |
RearDoorOpenSwitch |
Test to see if the rear door will touch the collision switch by its final position. If it does, will return true. and stop movement. | |
Return |
Properties |
