Author
Matrix TSL
Version
1.0
Category
Environmental
Barometer (DPS310) component
A barometric air pressure sensor with high accuracy and low current consumption. Capable of sensing air pressure and temperature. Based on an I2C bus connection.
SENSORS
ReadTemperature
Reads the temperature measurement from the last SampleSensor macro
- FLOAT
ConfigurePressure
Configures the pressure sensor sample rate and over sampling count
- BYTE
Rate
Range: 0-7, 0=1Hz, 1=2Hz, 2=4Hz etc
- BYTE
Oversample
Range: 0-7, 0=1Samples, 1=2Samples, 2=4Samples etc
ConfigureTemperature
Configures the temperature sensor sample rate and over sampling count
- BYTE
Rate
- BYTE
Oversample
ReadPressure
Reads the pressure measurement from the last SampleSensor macro
- FLOAT
SetMode
Sets the operational mode of the sensor to be continous or one shot
- BYTE
Mode
ReadAltitude
Reads the pressure measurement from the last SampleSensor macro and converts the pressure reading into an altitude reading.
- FLOAT
SampleSensor
Checks to see if new data is available for temperature or pressure and collects it. Returns 0 if no new data is available Returns 1 for pressure, 2 for temperature and 3 for both.
- BYTE
ReadRegister
Reads a byte from a register
- BYTE
Address
- BYTE
WriteRegister
Writes a byte to a register
- BYTE
Address
- BYTE
Data
Starts up the I2C ready to communicate with the sensor. Sets the selected rates and operational mode. Returns 1 if the sensor has been found and initialised.
- BOOL
Device Settings
Device Address
Measurement Rate
Oversample Rate
Operational Mode
Channel selection
Baud Select
Baud rate to be used
SDA
SCL
Stop Delay
Simulate Comms
No: Provides simulation using the panel component sliders. Yes: Communicates via an API Slave device to real world hardware, shows the results using the panel component sliders.
