Component: DAC (MCP4725) (MCP4725) (Analog Output)
Category Analog Output
DAC (MCP4725) component
Component to drive a 12-bit digital to analogue converter (DAC) IC from Microchip via an I2C interface.
COMMSA
Fc9-comp-macro.png SetOutput
Sets the output voltage of the DAC 12-Bit: Range 0-4095
Fc9-u16-icon.png - UINT DAC_Value
The value to output to the DAC
Fc9-comp-macro.png Disable
Disables the DAC output.
Fc9-comp-macro.png Enable
Enables the DAC Output.
Fc9-comp-macro.png Initialise
Configures the I2C peripheral ready for communications and initialises the internal variables. DAC needs to be enabled before any output voltage can be generated.
Fc9-type-16-icon.png Disabled Pull Down
Sets the pull down resistance when the IC's DAC output is disabled.
Fc9-type-15-icon.png Vref Voltage
Fc9-type-21-icon.png Steps
Number of discrete output states available from the DAC.
Fc9-type-14-icon.png Control Bits
Fc9-type-10-icon.png Resolution
Fc9-type-15-icon.png Voltage Resolution
Fc9-conn-icon.png I2C Connections
Fc9-type-16-icon.png User Address Bits
Specifies the bottom three "user" bits of the I2C 7-bit address
Fc9-type-16-icon.png Channel
Channel selection
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Baud rate to be used
Fc9-conn-icon.png Simulation
