Component: DMX 512 Slave (Comms: System)
Author MatrixTSL
Version 2.0
Category Comms: System
DMX-512 Slave component
A serial based communications protocol designed for controlling theatrical equipment such as dimmers, fog machines and intelligent lights. DMX-512 Slave devices are daisy chained together with a final 180R terminating resistor at the end of the chail. DMX requires the signal to be level shifted from VCC and GND to +2.5V and -2.5V.
COMMSC
DMX Slave Example, captures the first DMX data channel sent from the Master and outputs the value onto a Port using the LED array component. FC6 Icon.png DMX Slave Example1
For DMX 512 Master example see Component: DMX 512 Master (Comms: System)
Fc9-comp-macro.png GetDataChannel
Gets the data byte from a data channel
Fc9-u16-icon.png - UINT Channel
Fc9-comp-macro.png ReceiveDataChain
Waits for a BREAK, MAB and StartCode followed by the contents of the data channels. Returns 0 to indicate a timeout and 1 to indicate succesful reception.
Fc9-u8-icon.png - BYTE Timeout
0 = Don't wait, 1 - 254 = 1ms - 254ms, 255 = Wait forever
Fc9-comp-macro.png Initialise
Configures the UART serial interface.
Fc9-conn-icon.png Serial Properties
Fc9-type-16-icon.png Channel
Fc9-type-5-icon.png RX
Fc9-type-16-icon.png Baud Options
Fc9-conn-icon.png DMX Properties
Fc9-type-21-icon.png Data Channels
Number of data bytes to receive from the master, Max 512 bytes per transmission. 24 Bytes minimum from Master to match minimum 1204us timing requirements, not all channels need to be used.
Fc9-type-21-icon.png Start Channel
Channel from the master which we want to start taking our data channels
Fc9-type-7-icon.png Use Start Code
Do we wait for the start code or simply begin receiving data?
Fc9-type-21-icon.png Start Code
Start code value to listen out for, range 0-255
Fc9-conn-icon.png Simulation
Fc9-type-21-icon.png Console Columns
Fc9-type-16-icon.png Data Source
