Component: GLCD (SSD1327) SPI (SSD1327) (Graphical Monochrome)
Version 1.9
Category Graphical Monochrome
GLCD (SSD1327) SPI component
Graphical display component based on the SPI version of the SSD1327 monochrome graphical controller IC. Functions without the use of a read pin by hosting the 2K of graphical memory using the microcontroller's RAM memory.
DISPLAYS
Fc9-u8-icon.png - BYTE Font
Fc9-u8-icon.png - BYTE ScaleX
Fc9-u8-icon.png - BYTE ScaleY
Fc9-comp-macro.png SendCommand
Fc9-u8-icon.png - BYTE Command
Fc9-s16-icon.png - INT Number
Fc9-u16-icon.png - UINT X
Fc9-u16-icon.png - UINT Y
Fc9-comp-macro.png DrawLine
Fc9-u16-icon.png - UINT X1
Fc9-u16-icon.png - UINT Y1
Fc9-u16-icon.png - UINT X2
Fc9-u16-icon.png - UINT Y2
Fc9-u8-icon.png - BYTE Solid
Fc9-comp-macro.png Plot
Fc9-comp-macro.png ControlDisplay
Allows the display to be switched on and off
Fc9-u8-icon.png - BYTE Control
0=Off, 1=On
Fc9-comp-macro.png BPlot
Fc9-comp-macro.png Window
Fc9-u8-icon.png - BYTE Index
0=SpaceWidth, 1=PixelHeight
Fc9-comp-macro.png Refresh
Refreshes the entire display by sending the contents of the local RAM to the display at high speed
Fc9-comp-macro.png SetShadeIntensity
Allows the shade intensity to be set allowing for up to 15 different greyscale levels. Range: 1-15 Default: 15
Fc9-u8-icon.png - BYTE Shade
Fc9-u8-icon.png - BYTE PixelColour
0=White, 1=Black
Fc9-comp-macro.png DrawCircle
0=White, 1=Black
Fc9-comp-macro.png Initialise
Fc9-comp-macro.png InvertDisplay
Fc9-conn-icon.png Dimensions
Fc9-type-7-icon.png Flip
Determines if the display is flipped or not
Fc9-type-7-icon.png Auto Draw
Yes: Default - Lines, Text, Clear will all be done automatically No: Data will be sent only to the internal RAM, the display will be updated using the Refresh command
Fc9-conn-icon.png Colour
Fc9-conn-icon.png Bit Depth
Fc9-type-14-icon.png Colour Bit Depth
Fc9-type-16-icon.png Channel
SPI Channel selector
Fc9-type-16-icon.png Prescale
Prescale option selector
Fc9-type-5-icon.png MOSI
Fc9-type-5-icon.png MISO
Fc9-type-5-icon.png CLK
Fc9-type-5-icon.png CS / SS
Fc9-type-5-icon.png DC Pin
Fc9-conn-icon.png Fonts
Fc9-conn-icon.png Font 0
Fc9-conn-icon.png Simulation Mode
Fc9-type-16-icon.png Display Method
Allows the communications to be simulated to either see the waveforms on the data recorder or to drive an injector component.
Fc9-conn-icon.png Communications
Fc9-type-16-icon.png API
