Component: Gearbox (Mechatronics)
Category Mechatronics
Gearbox component
A simple component to couple together two rotating shafts via a gearbox. The gearbox can be used to scale the input rotational speed and optionally reverse the output direction.
MECHATRONICS
Fc9-comp-macro.png Rotate
Fc9-f32-icon.png - FLOAT Angle
Fc9-conn-icon.png Geabox
Fc9-type-15-icon.png Gear Ratio
Sets the input to output gear ratio. For example a ratio of 2:1 would be 0.5, a ratio of 1:5 would be 5.0. Negative ratio values allow the input direction to be reversed.
Fc9-type-17-icon.png Input
Input connection for example a motor or other active component or primitive.
Fc9-type-17-icon.png Output
Output connection for example a primitive or a component such as a linear slide or gearbox.
Fc9-type-15-icon.png Input Offset
Distance along the shaft from the center of the input object to the center of the coupling.
Fc9-type-15-icon.png Output Offset
Distance along the shaft from the center of the coupling to the center of the output object.
Fc9-type-15-icon.png Output Translation X
Distance along the X axis from the center of the coupling to the center of the output object.
Fc9-type-15-icon.png Output Translation Y
Fc9-conn-icon.png Panel Properties
Fc9-type-15-icon.png Width
Fc9-type-15-icon.png Height
Fc9-type-15-icon.png Depth
